Brake pad replacement?
I have a bad pad that's grinding. I'm going to do a full brake job later, but need to buy some time. I want to replace the pads. Any words of wisdom? I guess I need to lube the sleeves that mount the calipers and make sure they're sliding. Sent from my iPhone using Tapatalk
DO NOT get ceramic pads! They heat up and won't stop, especially if you've got weight...it's scary
IIRC, I think they are called metallic brake pads. I was told several years ago to never buy anything, but. IIRC, it was something along the lines of allowing the rotors to last alot longer, but the pads would wear a bit quicker. They also have better braking performance and are cheaper. I think the guy compared them to the ceramics and said steer clear of ceramics. So in this case, cheaper is better! Also, take a look at this! http://www.genosgarage.com/GenosGarageTechArticles/TDR51_BrakePadSpottersGuide.pdf http://www.genosgarage.com/GenosGarageTechArticles/TDR50_BrakeUtopia.pdf
I'll never use ceramic pads! The cars I work on get the semi-metallic pads. With quality brake pads the rotors will last 2-3 pad changes be for going undersized. With ceramic pad you'll be changing the rotors every pad replacement. Brake manufactures are trying to balance stopping distance,heat dissipation, longevity, dust, and noise.
