We are privately owned, with access to a professional Diesel Mechanic, who can provide additional support for Dodge Ram Cummins Diesel vehicles. Many detailed information is FREE and available to read. However, in order to interact directly with our Diesel Mechanic, Michael, by phone, via zoom, or as the web-based option, Subscription Plans are offered that will enable these and other features. Go to the Subscription Page and Select a desired plan. At any time you wish to cancel the Subscription, click Subscription Page, select the 'Cancel' button, and it will be canceled. For your convenience, all subscriptions are on auto-renewal.
- Replies 21
- Views 9.1k
JOHNFAK 9 posts
Mopar1973Man 6 posts
MnTom 4 posts
flagmanruss 1 post
Did This Forum Post Help You?
Not sure yet there's so much oil and hard to track down exact source even after cleaning 3x. Im starting to lean to the the oil leak is comming out of one of the two rear breathers due to excessive crankpressure (higher HP truck with ppump) . However I'm not sure what to do about it. Already have the 2 breathers. http://blogs.dieselpowermag.com/6817455/whats-new/cummins-vs-crank-case-pressure/ I've heard that a vacuum leak or turbo seal leak can cause that. Doubt its turbo as its new ...... Any ideas of input into this one. How to test vacuum leak/drawdown ...... and what do do about reducing oil leak. There is 0 blowby from the front oil collector at front, 0 blowby from the oil fill cap and I cant see any blowby at the source of the leak (tappet cover vents) whilst idle. Dont know if thats a clue or not ...... but engine seems real strong and healthy.
