Won't Start, 1693 Code
The rating for a relay has nothing to do with the load itself or the coil side. It is the rating that the contacts are rated for. That is why I said if you wanted to you could use one rated for 100 amps if you really wanted to. The load side should be fused BEFORE the realay should be sized to what the load is rated for.
Edited by MnTom
