issapro mechanical fuel pressure gauge install
I just installed my gauge according to genos garage instructions using there universal fuel hose not much drive time yet but every thing seams to be working good i have 14 lbs pressure at idle 11 pounds cruising and 9 pounds wot.As of yet guage reading is steady no eratic movement.
Sound like your lift pump is getting weak... Minimum lift pump ressure is 10 PSI... I'm going to garther your running stock fuel lines yet so I would suggest you think about a Big Line Kit From Vulcan Performance. http://www.vulcanperformance.com/Draw-Straw-II-1-2-in-draw-tube-and-1-2-in-pushlo-p/vpps9804.htm
