Hard start and more smoke
Over the last few months my trucks has randomly had a long crank to start issue. Only has happen maybe 4 times. It usually takes less then a second and shes running. But when this long crank happens it usually takes between 3 and 4 seconds to start. This always happens after the tuck has been sitting for at least over night.
Also the last few days I have noticed a light gray colored smoke coming from my stacks when I step on it. My truck is completely stock as far as turbo injectors or chips go and I have never before made smoke (which is how I want it ti stay haha) But the last few days it seems to smoke more.
Are these two issues related? What should I be looking for as far as problems go? Is the smoke normal on a truck with 197K miles?
Any and all input will be greatly appreciated, Thank you!
  • Replies 14
  • Views 2.7k
Have you scanned it for codes? That would be my first thing to do and see if there is something to point you in the right direction.
With that many miles on the stock injectors, I wonder if some of them are hanging open? That might explain the smoke.
I have not scanned it, I am hopefully going to do that today.
Injectors were my first thought but I wasn't sure if they would make this impact.  I was planning on replacing them soon as it is.
I used my buddies scanner and pulled up 2 codes. I got a P1693 coder and a P0460 code.
The P1693 code says it's a companion code? But not sure what that means
THe P0460 code is a fuel level sensor A circuit fault. Probablt explains my malfunctioning fuel gauge sensor that I just havn't gotten around to fixing LOL :doh:
There is no check engine light on, nor has there been in a long time. I scanned it 3 times and only got those two codes so I'm not too sure what to look at next.
The P1693 code is just a code that says you have a code in the ECM. it really doesn't mean much for you. What you are describing may be injectors, VP44, or your crank/cam sensor (causing timing issues).
That would make sence. Ive been reading that the P1693 code is like you said saying that there is a fault in the ECM, just not specific. It is usually paired with another code, But I only pull that code on the scanner.
I tend to agree the white smoke is possibly a injector issue. I would consider having them pop tested to see where your at. Typically its a free test.
Mike, I had plans of replacing my injectors in the very near future. It's actually the next upgrade on my long list of stuff to do. I was hoping to wait till I could get my new turbo and injectors together but if the smoke issue is pointing at a possible faulty injector I would just assume get them replaced with new ones now.
Could the smoke issue and the very intermitten hard start issue be related? And possily replacing the injectors could solve both issue together??
Thanks again guys.
My 02 did this same exact thing. I finally figued out I somehow was building vacuum in my fuel system. Next time it does it, go back and open the fuel cap and listen for a wooshing sound or leave your cap loose. If it were injectors, I believe it woould happen more often
I'm just saying test them to rule out any injector issues. This why I'm just suggest the test so we can rule out causes of why its smoking. You might just replace them and not gain anything or make the problem worse. This why testing is best before just through money and parts at any problem.
I agree with you on testing, I guess I misunderstood what you were saying.
How does one go about getting injectors tested?
Pull them out and run them down to a diesel shop or injection shop. They will be able to test them for ya or point you in the right direction at least.
So  found a place local that does free pop testing on injectors. I'm gonna pull them next week and bring them down.
Ive never pulled my injectors, I have watched the video many times though. What if any thing will I need to replace when I put them back in (Granted they are OK).
Connector tube o-rings and copper washers, 6 each. If you have about $400 kickin around, might as well have them rebuilt with better flow nozzles while they're out of the truck.
