Maybe its not the injectors
Diesel
Well, heres an update on my injector issue.
One of the good things about buying a truck that someone you know was the last owner is that when you text them about your problem they call you and say, " you know, the truck did something weird one time and you might want to check.............."
So what I was told to check was the fuel pressure sensor connection. Unplug it and plug it back in. I also blew in it for good measure. And wouldn't you know it, the truck has been starting good the last 6 days. Knock on wood, but it looks like it wasn't injectors after all.
Hmmm. The only thing I could see is if its showing the computer higher rail pressure so the fca isnt putting out enough pressure to start.
Bad connection will do strange things. It threw a code on him. Didn't throw one on me.
