Since I've been a big pusher of the ScanGauge II I'm now moving away from them. Being I picked up a Android Tablet for working on the web site I figured I would now pick up a OBDLink LX Bluetooth for diagnostics and also enhanced data. Like SmartyTouch has enhanced data like fuel temp and other things like Quadzilla and Edge does too. So if a person wants this information your stuck buying a expensive product. Now I'm working to get this data for the Common Joe.
Here is what I've got...
http://www.obdlink.com/lxbt/
Now here is the documents I've found for this project.
saeJ1979_2006-08-25Ballot.pdf
ISB_TROUBLESHOOTING_VOL_2.pdf
54262388-Cummins-Isb-Chrysler-FIS3666288.pdf
ELM327DSF.pdf
SAE J2178_2v002.pdf
K-line communication description_V3 0(1).pdf
Now I got to start probing the ECM for the data I'm looking for. I'll keep posting information as I find it. :wink:
Just a quick screen shot of the stock OBDLink Software and the few gauges.
  • Replies 31
  • Views 9.1k
  • Mopar1973Man
    Yes. Also allows for clearing all codes.   Why I'm going this route is to dig deeper like fuel temp at the VP44 which I know I can do. Now dreaming, maybe how many degrees of timing advancement on t
  • Just connects to the truck once downloaded, although some optional features can use some data if you enable them.(at least in torque) such as web upload of logged data, etc.
  • They are less than $70 on amazon and if you already have a smart phone or tablet is seems like a nice way to go.   Why do I have an urge to spend money after every post I read on this site?
First off let me be very very clear about something. OBDII information will not add more gauges than there is sensors for. So if people are looking to replace conventional gauges with OBDII directly it's not going to to happen. Being fuel pressure and EGT's are not part of the ECM sensor array.
So that being said I want to learn how to dig out the hidden bits of data that are floating around the ECM & PCM like fuel temperature and Transmission temp. Those would be a nice addition and goal to reach for.
As for what I know. I know that both my 1996 Dodge Ram (Gas) and 2002 Dodge Ram both use ISO 9141-2 (5 baud init, 10.4k baud). The refresh rate is roughly 4.2 PID's per second. I know that out of the standard OBDII data there is 10 known PID's for the 2002 and 14 PID's for the 1996. Being the 1996 is a 46RE automatic I should be able to tap the transmission temp sensor and get the fluid temp. Then on the 2002 Dodge I know the VP44 has the fuel temp sensor and modules like Quadzilla and Edge both can read this data from the OBDII port. The biggest thing is doing all the reading of SAE and different OBDII standards. Bad part is Cummins did NOT follow the OBDII rules so the extended data is going to be a bit tricky to find. Now are a rule of thumb most manufactures changed from Mode $01 to Mode $22 for extended data. But like after doing my study work for the past two days finding Toyota uses Mode $21 for extended data. So this just makes addressing a bit tough. So I've been digging into ScanGauge II and seeing similar things of data and addressing. That's what gave me the break I needed was looking around and finding header address 68 6A F1 used on most ISO 9141-2 even if you look close you'll see ScanGauge uses the same thing.
http://www.scangauge.com/support/x-gauge/xgauges-for-iso-vpw-vehicles/
Which now looking again tonight as I type this. I starting to understand the ScanGauge II X Gauge format in rough layout. TXD (Transmit Data), RXF (Receive Filter), RXD (Receive Data), MTH (Math). So after the ELM 327 document you'll see how the ScanGauge II does the data search for the information and displays it. But to keep the confusion down I like the Android Tablet idea much better because your working with human readable information and not strictly Hexadecimal like ScanGauge II.
So now just look at (link below) and look over the Mode $01 data. This is what most tools like ScanGauge II are capable of seeing. Now If you got the talent for ScanGauge II and Hexadecimal then you could follow along and get the extended data to work also.
http://en.wikipedia.org/wiki/OBD-II_PIDs
Now open this up and flip to page 15. These PRN's are the extended data hidden in the ECM.
Like PRN 102F is engine oil pressure, PRN 1044 Fuel Temperature, PRN 180B on page 16 is Transmission Temperature. Just going to take more study time.
I got to thinking and I have access to cummins insite at work so I looked to see if there was a simulator for the 24v on it and sure enough there was one for the chrysler cm551(24v), I can't get any PID's off it though (don't even know if they would be any good for what you are working on anyways even if I could see them since to hook insite up to the engine in a dodge you use a under hood harness plug(3pin) not the OBDII port) but anyway here is the list of parameters that would be reported from the ECM to insite in live data monitoring.
Edited by bjytech
  • 6 months later...
I think that I was going to buy a scan gauge so I could clear and trouble shoot codes but now I think that I am going to buy the ob2 mx scan tool so that I have the ability to read gm also. Does it tell you what the code is in the app or do you still have to look it up?
On the software it will do the look up over the internet for you as well. So it gives a P number and brief description and then you can do a look on the internet of more information. I'll see if I can produce a few screen shots for you.
I just got one of these... Is there a tutorial on how to set it up? I have no codes.. yay!
It says "not available" for VIN
Do I choose "Direct Fuel Rate"?  Volumetric Efficiency???
in the vehicle editor I see mass air flow rate, intake absolute pressure and direct fuel rate. Which should I choose and what does it mean? volumetric efficiency is defaulted at 65
Ok. Direct fuel rate for our trucks. As for the volumetric that is your offset to adjust the MPG number to get calibrated. As you change up or down it will change the MPG number for offset.
After looking at this I searched Cummins on Google play and they have their own app fault code adviser. Read and manage public j1939 fault codes and other data from your cummins engine.
Once you install the software it asks you to link to bluetooth obd2 device.
Edited by eddielee
