Maintenance and Wishlist Upgrades
- Replies 13
- Views 3.4k
War Eagle 6 posts
AH64ID 4 posts
Mopar1973Man 1 post
angus 1 post
Ball joints needed replacement so I thought I would tackle that job myself and then at the same I would install my Spyntech Shorty free wheel hubs that have been sitting in my garage for over a year now.
I also had a steering brace that I wanted to get installed.
While I am at it I thought I might as well do a needed brake job and replace the u-joints on the stub shafts since I had everything apart. I think doing all this work at once actually will save me a significant amount of time over doing each job separately when everything reached the end of its life.
While in the middle of the project I have made a note that I need to replace my front sway bar links as well because the bushings are coming apart and look very tired and worn.
The plan is when all this work gets done then I put my 19.5s back on for the season.
I have one side completed now and am working on the other side now. Can't wait to try it out after all the work is done. I'm thinking there will be a noticeable change in the driving feel!
Hoping for an mpg increase also!
