Best option for rebuilt ECM
- Replies 34
- Views 8k
Mopar1973Man 10 posts
Tim Waldo 10 posts
JAG1 8 posts
Buzzinhalfdozen 3 posts
Ok... I've followed most of the steps (yes only most) but I get to Number 8 on this diagnostic tool and I get 44.2k ohms.... a bit more than the 5 or less suggested value. Where is the best place to purchase a replacement or have mine rebuilt??
Thanks,
Tim
http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/59-obdii-error-codes/175-p0336-crankshaft-position-sensor-signal
8. Ensure CKP sensor connector and ECM connector are still disconnected. Using ohmmeter, checkresistance between ground and terminal "C" (Gray wire) on CKP sensor connector. If resistance is 5 ohms or more, replace ECM. Perform TEST VER-5A . If resistance is less than 5 ohms, repair short to ground on Gray wire between CKP sensor and ECM. Perform TEST VER-5A .
