order of reliability improvements/over heating
Hi all,
There used to be an order for doing the step by step improvements on a VP44 truck, does that still exist? Bought a clean 2000, 2500 4x4 club cab & need that list for a reference. I will get an Air Dog Raptor & a Fuel Gauge. Also need a temp gauge for the Auto. Is that still the way to go?
So my 1st sort of concern. I was coming back from Canada pulling a 24' pontoon boat on a 28' trailer no worries until I got to the border, as we sat for an hour, wasn't that hot, drove about 200 miles w/o the A/C, my engine temp gauge started rising till about the 3/4 mark. So waiting in line I quickly raised the hood up to give a quick check & noticed that the A/C kicked on by itself & started cooling the engine, I noticed the condensation puddle under the truck along w a green antifreeze puddle in front under the radiator on the driverside. Don't think it was from the upper hose but maybe the bottom. I had to quickly close the hood & move the truck. As I moved there were no more green puddles, also the engine temp gauge was getting back to normal running temp.
So I have no leak at the moment. How did it heal itself? I'm keeping an eye on it. Anyone with a similiar situation. My 98 would idle all day at any outside temp & not change from the reg running temp.
What to do? The PO replaced the head gasket w better head studs only to find out it was one of the 22 soft plugs that had a leak.
Thanks,
Dave
  • Replies 38
  • Views 8.5k
They went w the 48RE in 2003, but the trucks are also bigger!
Are these weaknesses unique to 2nd gens? Or to later years also have these troubles?
I don't have a 3rd gen... However, from hearing Wild N Free talk about it, it would appear that they made the 48 a bit stronger.  Still not free from mods for performance applications, but they seem to tow well without mods.
ETA:  I wish I bought a 3d gen!  Haha.   But... I love the blue beast.
Edited by CSM
I think the manufacture date on my Air Dog Raptor 100 makes one of the newer version pumps. It's been on there for about 5 years with about 25,000 miles on it. I can hear the bearings squealing at times but still holding around 19 at idle and around 15 hauling heavy up hills. Time to request a new one since the mount is an easy frame mount change out
Personally, I'd get a fass.
The whole fuel system weakness is the VP44 at the center. Basically there is 4 ways of killing a VP44...
  1. Fuel lubricity - Bosch states in there own testing that all fuels should be at <450 HFRR but US fuels are about 520 HFRR.
  2. Fuel pressure - Dodge FSM states a minimum of 10 PSI. Unoffically we state a minimum of 14 but no higher than 20 PSI. This is to hold the overflow valve open.
  3. Fuel filtration - Extra filters or better filtration is always better for life span of parts.
  4. Power - Yes even the VP44 is sensitive to AC noise as well and should be less than 0.1 AC Volt measured at the BATT post on the alternator.
CSM is right this is just a old school 727 trans in these truck with a electronic 4th gear. The problem is that the 727 and the 47RE are designed to handle max torque at higher RPMs but like the Cummins it create high torque in low RPMs and the pump pressures are not high enough during these loads. Hence why people change valve bodies, add pressure and modify the governor pressure signal with a resistor. I know Wild & Free could spit out the newest transmission model and it would be a huge upgrade over the older 47RE and 48RE.
What one? Someone on here said the the Dodge Direct Replacement was junk! I have about the same miles on my Raptor!
  • Fuel lubricity - Bosch states in there own testing that all fuels should be at <450 HFRR but US fuels are about 520 HFRR.
  • Fuel pressure - Dodge FSM states a minimum of 10 PSI. Unoffically we state a minimum of 14 but no higher than 20 PSI. This is to hold the overflow valve open.
  • Fuel filtration - Extra filters or better filtration is always better for life span of parts.
  • Power - Yes even the VP44 is sensitive to AC noise as well and should be less than 0.1 AC Volt measured at the BATT post on the alternator.
Would a shift kit be good enough instead of changing out the VB?
I have an older model fass 95/95.
No idea on the direct replacement.  I've been hearing many many stories around here of the new Air Dogs not being as reliable as the old ones.
In many cases, yes.  Caj Flynn (old poster with a million mile 2d gen) used the shift kits.  I am not sure what kind he used though.
I have a Dodge Direct replacement and i would not recommend it. The first one mounted in the stock location lasted about 10K miles. Second one is mounted on the frame and after 15k miles it is starting to leak fuel out of the motor so its days are limited. I will be ordering a FASS system soon.
In many cases, yes. Caj Flynn (old poster with a million mile 2d gen) used the shift kits. I am not sure what kind he used though. [/quote
It would be nice to know how I can make an auto more reliable, seems like I can destroy even a NV5600, driving easy!
I have a Dodge Direct replacement and i would not recommend it. The first one mounted in the stock location lasted about 10K miles. Second one is mounted on the frame and after 15k miles it is starting to leak fuel out of the motor so its days are limited. I will be ordering a FASS system soon.[/quote
Isn't that a FASS, the direct replacement?
That's what I thought!
So I bought a Raptor today, I had no issues w mine in my 98.5 & I believe it kept my VP44 going after I got the death code 40,000 miles ago. I will fill in my warranty
as soon as I get it just to be sure it's cool! I'm taking a chance, I've read of problems w Air Dog & FASS, so I just went w what worked for me!
Still researching the shift kit or a VB, but that will have to wait untill I get my radiator sorted out when I get home & a FP gauge, not sure if I want a monitoring system or something along those lines!
Any thoughts?
Dave
As long as you can increase the line pressures properly.
I bought a SunCoast shift kit for under a 100 bucks, it's supposed to take care of the line pressure problems. I appreciate the helpful suggestions here guys!
I can't wait to get home & start changing parts, it's a rust free Fl truck, so I had no problems changing the front shocks & removing the shock tower bolts!
Michael, I know you were writing about getting rid of your Frantz but I'm switching mine over from my other truck. I don't care if it does seep a little, the oil is silky smooth! It's worth it!
Thanks again guys,
Dave
Update, I looked at my shipping notice & the shift kit is a TransGo ordered from SunCoast.
After I get the farm caught up when I get back, I'll be having fun putting my goodies on the truck next week!
Keep y'all posted,
Dave
