47RE build suggestions
- Replies 29
- Views 10.2k
Vais01 9 posts
440Rat 6 posts
ronman 4 posts
CTcummins24V 3 posts
I've read Dynamic's posts about not using Alto Red frictions and steels, so what else do I need to know? I'll be doing it myself (with the assistance of a Chrysler master transmission tech) in a nice, clean, air-conditioned garage, and I'll be pressure-washing the underside of the truck and the transmission case once it's out.
Problems currently are no 1-2 shift unless I lift completely off the throttle, and a leaky rear seal. The kickdown lever is broken, which allows the 2nd gear band to float free above the drum. 2-3 and 3-4 are essentially normal shifts.
I've already got an FTI single-disc converter and a Suncoast billet governor solenoid plate and oversized/GM solenoid.
I don't realistically see the truck ever being modified to make more than 350-400hp.
So, what parts should I use? Does anyone make a decent, comprehensive kit that includes all the gaskets, seals, etc. in addition to the recommended Raybestos "hi-energy" clutches? What about oversized pistons/servos and accumulators? Any upgrades to 48RE hard parts that can be done while it's apart?
I have no desire or intention to open up the overdrive section of the trans.
So, suggestions/tips/recommendations?
