- Replies 29
- Views 14.3k
fire176969 7 posts
Vais01 7 posts
TFaoro 4 posts
CSM 2 posts
It's pretty common. There's at least a few threads about it on this site alone. Happened to me once. One theory, that I particularly like, is that while standing on the throttle, maybe timing is a lit
Ease out of the throttle and should fix it. Bigger high pressure lines and drilled out fuel connector tubes seem to make it worse.
Having an issue and just starting to look for the cause. Have a 1999 24v with a 5 speed transmission that will shut down after you let off the accelerator when you accelerate hard. After it dies you have to crank the engine excessively to get it to restart. At times it won't restart unless you pull/coast start it or bleed the injector lines.
