The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
Well Gang,
The Board of Directors on the Mopar1973Man.com has decided that we need to produce some new High Idle Switches for the 2nd gen 24V Cummins.  We have spent a considerable amount of time designing a Brand New High Idle / MPG fooler Switch.
We have learned from the last switch design and have made significant improvements.  The New High Idle / MPG Fooler switch will be the same price as before, but it will be more robust and modular to allow for easier install.
We have decided to only offer a "Install Anywhere  Kit" rather than a gauge mount or Cubby Mount.  You will nly have to drill one 1/4" hole to allow for the fitment of the switch.
Some teaser pictures.
We are making 50 switches to start then another run of 50 after that.  You can order them from The Mopar1973Man.com Store I expect to have them ready to ship within a 6 week time.
  • Replies 438
  • Views 63.3k
  • Got my switch installed. I'm about to jump over to CF to post a quick install write up, I just wanted to share that the switch does in fact fit in the overhead console. As already discussed, the wire
    All high idle sales will be here on the site for here on out. We will be the producers, vendors and the support team rolled into one...
  • I finally installed my high idle switch today.  I put in in the overhead console.  The cable that comes with the switch is just a little too short.  I ordered a 12" extension from Amazon and I was abl
Yea you won't have any issues posting pictures / saying stuff on CF.  just the staff and so forth over here.
I finally got mine actually installed, so I took some videos.
I will have to do a video of the 3cyl and EB enabled, I can get egt temps of 1000*f without much issue.
Edited by Me78569
20 hours ago, Me78569 said:
No you are right in thinking that 1/4 is too small.  I forgot to update the install direction.  Needs to be a 3/8 hole.
Pull the switch out and redrill the hole 3/8 big so the threads come through the hole fully.  Then use the locknut to secure it.
That's what I ended up using/doing. Just wanted to make sure I wasn't loosing my marbles! The way it's installed now, it shows hardly any thread because I have it on a rounded part of the kick panel but it still works out really well as far as rigidity and all.
Alright here is a video of the basic operation and what the high idle swtich does in each mode.
Wonderful,
I put mine in the same spot finally today haha.
Added a enter key after the youtube link to post.
That's a cool vid Nick, what software and viewing platform are you using?
I totally forgot I have a CF login and such from way back so I'll hop on there at some point and show off the switch as well, or just hop on sleezys thread and brag about it as well. :thumb1:
Alright,
Here is another simple one of me installing the switch into the kick panel.
I just used my andriod phone and youtube haha.  Nothing edited.
Wrong video the first time
Edited by Me78569
Again adding a enter key to display video.
ooo sorry, thats the quadzilla tuner.  Uses bluetooth to port info to an andriod device.
More videos,
Harness install
Kick Panel install part 1
Kick Panel Install Part 2
I have installed the switch, had the dealer enable the high idle with 3 cyl mode, but the high idle will not function. I had the dealer confirm that they enabled it correctly, and on 6 cyl mode the temp gauge on the dives, so I believe the switch is functioning correcting. Has anyone run into anything similar? I swapped the 47re to an nv4500 this summer and did not replace the apps (did re-calibrate), or ecm, only hooked up the reverse lights and the clutch safety switch (for cruise). The truck runs great, and I would really like this to function any ideas would be much appreciated.
Uh Oh?!
Did you mess with the voltage setting of the APPS sensor? If so it will cause issues.
http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/26-engine-systems/37-apps-sensor-voltage-adjustment
I only did the battery disconnect wait and press the throttle. I did not alter the voltage at all.
The ecm will disable High idle mode if
1. brakes are pressed
2. throttle is pressured (think your issue is here)
3. ECT temp comes up ( which you say your coolant drops on the gauge so this isn't the issue)
4. assuming clutch pedal is pressed
I would start with the app's though, if you adjusted it and the truck see's ANY throttle input at idle state the high idle will never happen.
Do you have any way to read the live data from the ecm? OBD reader, edge altitude / quad
Your clutch enage might able be to blame.
Edited by Me78569
I do have an OBD reader it can only take snapshots of the engine, and it reads conditions that should trip the high idle. I did think about the clutch switch and simply grounded it, re-calibrated  the apps again, no difference. The truck seems to run fine with out doing anything to the ecm although that does not mean I am missing something.
I havent heard about the Signal P/N what needs to be done to accomplish this?
If the P/N signal is referring to the park neutral signal being sent to the ecm I believe grounding out the transmission is sending the signal of park to the ecm (I disconnected it from the clutch safety switch and grounded it) and the 6cyl still did not function. I have read that there are different apps for auto and manual would this have any impact?
Edited by isaac hall
39 minutes ago, Me78569 said:
Signal "P/N"
Edit: Siganal from the Park/Nuetral safety switch. Sometimes I fat finger the screen on my phone.
I thought that was one of the conditions for high idle to work on an auto. Now that I think about I don't think that's correct.
It is. if you take it out of P it will disengage high idle.
