The time has come to produce the Mopar1973Man High Idle & MPG fooler switches again.
Well Gang,
The Board of Directors on the Mopar1973Man.com has decided that we need to produce some new High Idle Switches for the 2nd gen 24V Cummins.  We have spent a considerable amount of time designing a Brand New High Idle / MPG fooler Switch.
We have learned from the last switch design and have made significant improvements.  The New High Idle / MPG Fooler switch will be the same price as before, but it will be more robust and modular to allow for easier install.
We have decided to only offer a "Install Anywhere  Kit" rather than a gauge mount or Cubby Mount.  You will nly have to drill one 1/4" hole to allow for the fitment of the switch.
Some teaser pictures.
We are making 50 switches to start then another run of 50 after that.  You can order them from The Mopar1973Man.com Store I expect to have them ready to ship within a 6 week time.
  • Replies 438
  • Views 83.4k
  • Got my switch installed. I'm about to jump over to CF to post a quick install write up, I just wanted to share that the switch does in fact fit in the overhead console. As already discussed, the wire
    All high idle sales will be here on the site for here on out. We will be the producers, vendors and the support team rolled into one...
  • I finally installed my high idle switch today.  I put in in the overhead console.  The cable that comes with the switch is just a little too short.  I ordered a 12" extension from Amazon and I was abl
I have the Superchip, would this play any roll in the operation of the high idle? I need to test my truck to see if it's activated.
On December 13, 2015 at 10:30 AM, Me78569 said:
Please let us know,   We have record of the strange behavior so we will be able to pick up the issue if it does happen a month from now.
Thanks For your service, we will take care of your issue if it continues to be a problem.
It's back doing the same issues plus it takes out my temp gauge if I'm driving in 6 cylinder mode also. I tried switching it to the 6 cylinder mode before I start the truck like Moparman said to do in a post which works sometimes. When it goes into the 3 cylinder mode instead of 6 cylinder mode then I've just let it run that way but would like it fixed.
If the truck is parked you can use 3 CYL or 6 CYL mode only.
If the truck is moving or being driven then you can use OFF or MPG mode only.
You cannot use 6 CYL or 3 CYL modes while the truck is moving. 6 CYL mode fools the coolant temp really low so the high idle can start. Which it cannot start because the speed is above 0 MPH and TPS is above an idle. Using either one of these modes will degrade MPG numbers.
I am move them willing to test your switch for you, but I would ensure you aren't trying to drive the truck in high idle mode.
The coolant gauge will go to the bottom if it is in 6 cyl high mode, that is how the switch is designed, without that the switch could not do prolonged high idle mode.
Mike, when is the next batch of switches going to be available?
On 10/10/2015 at 6:49 PM, Mopar1973Man said:
Two methods...
  1. Dealer and provide the article here. -> http://articles.mopar1973man.com/2nd-generation-24v-dodge-cummins/64-mopar1973man-com-high-idle-kit/440-tsb-18-019-01-cold-idle-engine-warming
  2. Barrow a Smarty Tuner - Just run one tune the return to stock.
also do you have the new link to this tsb? id like to print it out and get my truck flashed to enable high idle etc...
Edited by CUMMINSDIESELPWR
I am looking for it now.  we will update the thread once that is moved.
We haven't heard anything from you about your switch. Did you want me to test it out for  you?
The next batch of switches has been made.  we are waiting for the harness to be made. we are hoping get those soon!  please check the store for updates.
Yes, testing it will be fine, not sure why I'm not getting notifications. You have a phone number that I can talk to you first or a email??
Edited by firemanram
I dunno if I have asked this before or not, but do you have anything to read live data from the ECM?  ( quadziila, edge attitude, scan gauge, etc)
Edited by Me78569
Sign me up folks! One question, will I be able to borrow a friends smarty( that's already flashed his truck) to enable my high idle?
Yes,
You will just have to return his truck to stock, load any tune onto your smarty, turn you truck back to stock and return the smarty your friend with a 6 pack of his favorite beer
Which issue?  I am missing it I guess.
Sorry....
Extended idle operation, especially in cold weather, can lead to stuck valves and bent push-tubes due to insufficient cylinder heat. This allows varnishes/oils to condense on the exhaust valve stems, leading to stuck valves, and damaged valve train components.
When we go hunting, snow and ice can accumulate on Windows requiring warm up prior to driving. Temps in the low teens are common. 3 cylinder high idle seems perfect for these conditions...but do we need to worry about damage to engine?
Edited by joecool911
I think they are talking about extended non-high idle idle.
Correct. I use mine quite a bit for exactly what you asking about. I go into the back country to help ranchers from time to time. So spend the night at a remote cabin and get pu in the morning to a windshield loaded with snow and ice. Kick the exhaust brake on and 3 cylinder high idle and pop the EGT's right up to 800*F and heat in the cab in about 5 minutes.
That's awesome! I don't have exhaust brake though. What about a potato in the tail pipe?
