2007 5.9 Fuel Pump Fuse or Relay Location
- Replies 32
- Views 42.2k
dorkweed 9 posts
dripley 9 posts
AH64ID 7 posts
Mopar1973Man 4 posts
I am looking to locate where the fuse or relay is on my 2007 5.9 3500 Ram. I have searched hi and low to no avail so hope someone can give me some good direction. This truck has the TIPM module and there is no indication on the cover of a fuse for the fuel or lift pump. My dealer is a bit shakey but indicates the fuel pump which is located in the tank is controlled in the solid state circuitry of the TIPM so there is no assessable fuse or relay. If true and if I want to disable the fuel pump for a test I would have to find the connector somewhere back by the fuel tank and disconnect. Is this the situation or is there another more accurate procedure?
