Overdrive button
I am having a problem with the overdrive button. Most times I have to press it numerous times to get it to engage. What's the fix?
  • Replies 10
  • Views 3.3k
Nick might be able to help with that. I live the manual life!
Row, row, row your truck, all the way across town!  :poke:
You can pull it apart and try ti clean it, it is nothing more than a momentary on/off switch.
I would assume the issue is not in the cleanness of the switch though, I would assume the contacts are worn out.
Well.. I took it apart last night and following the instructions to clean the contacts with an eraser plus apply a little dielectric grease to the prongs.. it worked beautifully today with the softest touch! See how long it lasts :-)
I bet you didn't shoot any pictures of you doing this so you could make a article... (Hint, Hint, Hint!)
I take pictures of everything :-) Do I just post it in a thread or is there an article place to do it?
I could give you account on the article database and you can make it yourself. I need you yo PM me a password you want to use and I'll create the account for you.
