Help Identifying Big Leak (Probable Vacuum Pump)
- Replies 14
- Views 3.1k
Me78569 5 posts
Nates1999 5 posts
Wild and Free 2 posts
dripley 1 post
So I noticed yesterday that I had a decent little puddle of oil under my motor yesterday when I went outside. Nothing huge, but more than the nothing I usually see. I'm having a hard time figuring what it might be though. I kind of figured it was the vacuum pump leaking, but I don't see an actual leak from the junction point between the power steering and vacuum pump. It might be coming from further forward. I'm getting most of the leakage down onto my pitman arm, then blowing over my front suspension etc.
What I've Noticed:
-Oil dripping down the driver's side near the frontish part of the motor, definitely somewhere behind the timing cover. Most drips down onto the pitman arm.
-No leaking evident from tappet cover, and I think I can see it pretty good.
-Power steering is down a little (between hot and add, when the engine is hot), but that's not surprising, as I know the hydroboost is leaking a tiny bit at the brake pedal, but I suppose it could be power steering fluid.
-Oil might be down a hair (maybe half a quart), but it could be just from being on uneven ground.
My Question:
Is there anything I can do to pinpoint the leak? Anything I should be doing that might make it more evident? Maybe have someone turn the wheel while I'm under there with it running?
