Is it worth adding 2-cycle oil to a P7100 truck?
I know it helps save the VP44 pumps but what about a P7100? I think it would be beneficial but I would like to here from those with more experience on the matter. If it is a good idea, what ratio of oil to fuel should I use? Just for clarification there is nothing wrong with my pump, I'm simply looking at preventive maintenance practices.
  • Replies 42
  • Views 12.3k
Mike when you say at highway speeds you talkin 4th gear locked? I've never been able to do that without unlocking the TC.
