Heater Core Servicing
- Replies 16
- Views 4.3k
Mopar1973Man 5 posts
dripley 5 posts
CTcummins24V 2 posts
Wild and Free 1 post
Popular Days
Do it all and be done with it.
Dash must come out and If going that far I would never reuse a modern aluminum heater core for the amount of work it takes to get in and out. Replace it and forget it for another 200K.
If your going to get to the point of doing the heater core you might well service the entire HVAC box and know everything works correctly.
I want to bring your attention to heat core servicing. I know there is a thread over on CF explaining on how to do the short cut method where you cut the tube ends and hose clamp inside the truck. This gets around the idea of having to recharge the A/C. I would like to advise against this method being so far the HVAC I've open in the years all them are truly funky looking with everything from mice nest to like this one with packed hay and road dust. If you going to do a heat core do it right and take care of everything. This includes the stepper motor for the blend door, dust and debris on the system, check your blower motor for problem and resistor.
