- Replies 22
- Views 10.2k
JesseJames 7 posts
The_Hammer 6 posts
CSM 5 posts
dripley 2 posts
Your talking about the oil cooler. It is a type of heat exchanger, but is normally referred to as an oil cooler.
Oil leaking past your turbo? Oil in the intercooler? Bad injector(s)? Might consider pop testing.
The heat exchanger you speak of isn't a part of the block, it's mounted to the block. If it leaks you'll get ATF in your coolant, but it has nothing to do with the truck blowing white smoke.
I have a 1998.5 3500 5.9 Vin 6 24v CTD, have put in a remain VP44 from O'Reillys, a new lift pump that puts about about 16 psi WOT, DAP 100HP injectors, and have done a block test and still cannot manage to figure out why i have white smoke at WOT. It blows a puff of white on a cold morning but after reaching OT my programmer kicks on and it'll be black for a while then it seems as if randomly it'll turn white, then if i turn my programmer off it still smokes white. I have no idea from here. Any ideas?
