Some needed routine maintenance
- Replies 16
- Views 4.3k
Wild and Free 6 posts
angus 4 posts
CSM 3 posts
Mopar1973Man 1 post
Update, got all the parts yesterday. Today got the power steering pump line and trans cooler line installed along with my shiny newly rebuilt Bluetop steer gear. Pulled the track bar and replaced the
I just follow the specs and use a dial type inch lb. tq. wrench. Ryan @ Blue top has gotten out of the automotive gear business to focus on the truck end of things but will still do them if he ca
This is one of the reasons I like to keep 3 or 4 drivers in my fleet. If something breaks or you have to do some maintenance no big deal just work on it at your leisure. At least that's how I justify
Since the 05 is just a backup rig and tow rig primarily it has not been used a lot the last couple years, "7500 miles on it since the last service August of 2014" . Decided since the steering is getting loose it was time to get her on the hoist and look her over and do a major end to end service including all filters all fluids except coolant, did a t-stat last service and it was replaced with new then and adjust trans bands.
Pulled the steering gear out and sending it to Blue top steering steering for a "Quality" rebuild since this is already a cardone replacement several years ago and already loose as a goose. Herding cats down the road in a straight line would be easier, all other steering component look to be good and tight yet except for the leaky dripping damper.
Put in an order @ Genos garage for a full set of 5100 Bilstein shocks and steering damper which mine is totally shot with oil dripping out of it which prolly doesn't help with the wandering issue and also ordered lukes links track bar bushing kit as long as I am working in that area anyhow.
Found the power steering pump hose going to the hydro boost starting to leak along with a tranny cooler line above the steer gear leaking pretty good too, got them all ordered as well, rock auto for the steering pump hose and e-bay for the trans hose.
Now we wait for parts this week.
