Scangauge 0 LOD/0.0 GPH at idle
- Replies 16
- Views 4.6k
Mopar1973Man 5 posts
dripley 4 posts
alfonzo27 3 posts
AH64ID 1 post
No problem. I keep all of this running so Mike can sit back and take a lot of naps. He is quite good at it.
Load is reported by the ECM and GPH is calculated by the SG. Load is simply the ECM converting fuel flow to a number, which is why there should be load at idle, 4-6% normailly. If load is
Evening Gals and Gents,
Having Issues with my Scangauge. It doesn't report load(LOD) correctly.
It's showing 0 LOD at idle. This results in 0.0 GPH at idle.
I have contacted Scangauge and am currently emailing with them to hopefully find the problem.
For those of you with a Scangauge what do you show for GPH and LOD at idle?
How is LOAD calculated?
I can even see 0 LOD when TPS is greater than 0. I found this out while coasting downhill in neutral and slowly pressing throtle down.
I do have codes stored: 0622, 0743, 1595, 1765
I believe most of those codes were related to the Mystery Switch Lockup control
Other Known Problems are Alternator VAC to high(cycles between 0.065-0.156 at idle)
Thanks!
Currently running a 2002 Ram Cummins 2500 Quad Cab Automatic. Mostly stock except RP-100 and edge programmer.
