1999 Dodge Dakota Intake Manifold Gasket
- Replies 11
- Views 4.6k
TFaoro 3 posts
Hawkez 3 posts
Mopar1973Man 2 posts
Me78569 2 posts
Popular Days
Josh ask your dad to take a white rag and wipe the inside of the intake tube. Do the same to your truck and tell him the cleanest one gets a free lunch at the good place.
Another job dropped on my door step. Local gent was having issues with his Dakota with a misfire code P0304. It's the little V6 engine. So I told him to order the gasket for me and drop it off and I'll get it changed out. You'll notice the oil in the inside of the manifold which is typically when the plenum gasket fails. It will start drawing air from the cam valley drawing in little bits of oil. The owner also admits the truck had a K&N filter. You'll see the amount of grit and dirt let into the manifold. Little trick to pass along is while your scrapping the manifold gasket off take a shop vacuum and keep it near the area your working and the vacuum will pull in the bits of gasket material as you scrap. Nearly nothing for debris in the cam valley this way. When torquing the bolts for the plenum and the manifold you need a INCH / POUND torque wrench. Manifold is final torque at 12 FOOT / POUNDS or 144 INCH / POUNDS. The plenum is final torque 84 INCH / POUNDS. Nice part is when I fired it up the miss is gone and the CHECK ENGINE light went off by itself.
Yes. I'll clear the codes to make sure the slate is clean.
