- Replies 17
- Views 4.6k
jamman 8 posts
Me78569 3 posts
notlimah 3 posts
Mopar1973Man 2 posts
You have no tuners that do boost fooling according to your sig correct? If that is the case I would guess that you
I suppose it depends what you're definition of cheap is, but I use THIS. I know @Mopar1973Man is a fan of that setup as well and has good results, as have I.
I hear ya! Nothing on these trucks are cheap! I have a gauge combo from Vulcan sitting in the garage about to get put in my truck. This is my second one I've bought from Eric and it's always a qu
Let me paint the picture.
Monday of last week saw me begin driving ~120 miles/day to a new job. I filled the tank up on the truck that weekend. I had not topped up with 2 cycle lately, but had a residual amount in there that I felt was sufficient due to always putting in either 16 oz or 32 oz, just depending how close I was to 1/2 a tank or a full tank. Oil checked out good, trans fluid ok, etc. Good to go.
Monday morning. 30~ miles in, hit a valley and as I start to pull up out of the hill, I can't hardly get her to go. It lacked power. It wouldn't downshift like it normally does when it grabs a gear to pull. The turbo wasn't spooling up. And it would sort of sputter sometimes and lug down. But nothing was consistent. At times it acted like it might get power, but then just wouldn't go. I limped like this the rest of the way to work. All the way I was trying to think it through...Do I have water in the fuel? Do I have something getting sucked up on the diptube? Have I got a plugged injector? Have I got a fouled fuel filter? What??? Took the truck ~5 miles for lunch, and it wasn't a power beast, but wasn't as bad as that morning.
I get in the truck that evening and it drives just fine. Like she normally does. I go to O'Reilly and they pull the codes for me and all I have is a P0234-Turbo Boost Limit Exceeded on the Bosch Scan tool the tech used. It's too late for me to do anything, so I just dread the next day driving to work. Drives just fine. I run 2.5 days on that tank and then fill up. I got about 14.4mpg on it(hand calc'd), which was great as I was anticipating about 12mpg from previous performances. I fill up, and I honestly can't remember if I added 2 cycle. Truck continues to run great. I finish out the week. I fill up the tank for the week to come. 16.2mpg!!! I don't even put in 27 gals of fuel for something around 430 miles(all from memory, records out in truck). This time I add 32oz of 2 cycle from WalMart and I am ready for Monday morning.
I warmed the truck for a long time (30 mins+) this morning and she was fully warmed up. I pulled off the farm and thought I felt reminders of last Monday. Sure enough, it starts doing a similar batch of loss of power. Never as extreme as last Monday, but certainly a loss of power and missing what I would call downshifting for power and not the usual boost I would feel and hear. Guess what happened this evening? Yep, drove just fine. Not a hint of issues.
Have I got trash in the tank? Do I have a dirty wastegate that needs attention? Have I got a cat stuck in my injectors and gumming up the works? What is going on?
I would appreciate any lucid ideas!!! I'll get you any answers/info I can. I don't have anything on the truck as far as gauges right now. All stock.
Thanks all!
