- Replies 21
 - Views 5.8k
								notlimah 8 posts
								Mopar1973Man 4 posts
								dripley 3 posts
								TFaoro 3 posts
Popular Days
Don't replace, instead diagnose When it's cold enough for the grids to kick on, flip the key then jump out and feel the grid. You should be able to feel some amount of heat coming off of them.
4 years isn't much for batteries.... you'll know when they're starting to go.
65*F and lower should trigger at least 1 grid heater. I'm not sure when 2 is triggered. Then again that why I suggested a second person turn the key to ON while the other is probing quickly to
So on initial start ups, I've noticed that there tends to be some white smoke. Only one time has it been to the point where I was like man, that's a good amount haha. Other then that, its just a little bit, not even really noticeable in my mirror. Anyways, every time I start there always seems to be a slight hiccup at start (I'm thinking this may have to do with the stock intank lift pump so I'll update once the fass is on) but she idles out smoothly after a second or so. It was around 48* this morning. I have a typical wait to start time, fire her up, and again, have a little white smoke. I then waited to see if my grid heater would kick in with the voltage drop and nothing happened. Eventually it looked like it tried to cycle the grids but the voltage barely dropped to the 14 mark. Do I have a bad sensor? Need new heater block? The truck seemed to have a VERY slight hiccup at idle, barely even noticeable, but I was thinking it may have been from the lack of grid heater?
Keep in mind, the one time I've started the truck after being plugged, none of these symptoms were apparent.
