- Replies 34
- Views 5.3k
Mopar1973Man 9 posts
Me78569 8 posts
dodgedieselnewbie 8 posts
TFaoro 4 posts
Here is the article on Edge settings.
So the wiretap connects to the fueling solenoid in the VP44. I am GUESSING, again GUESSING, that since you check for 12v when the truck has power but not turned on for the wiretap, that ground
the chart is for wiretap. Your edge not wiretapped cannot put out more than 65 hp over stock or lvl 2. Anything over lvl2 is no different if your wiretap is not plugged in.
I decided to upgrade my injectors and while in there adjust the valves. Thanks moparman... for the write-ups! BIG help! Other than breaking the breather nipple.. everything went smoothly. Much easier than I anticipated. Only issue I really had... was getting a torque wrench on the back most fuel line nut.. so I just guestimated with a regular wrench. Also decided to do a grid delete and have my intake and valve cover powder coated.
Throughout the whole process.. I was so nervous that when I finished it wasn't going to start or run as well as it did before I stuck my hands in there. Well... it took around 4 times cranking before I heard it turn over... music to my ears :-) It coughed just a couple times.. then smoothed out and was purring like a kitten. I installed the valve cover and intake a couple hours later and took it for a spin.. runs great. yay!!
Thanks again for the info.............
Pic of valve cover and intake
BTW.. One of the connector tubes looked funky on one side... can someone tell me why or what the cause is/was? I wire brushed and reinstalled...
Edited by dodgedieselnewbie
