- Replies 43
- Views 9.1k
I worked 11 hours today. I emailed Eric last night and thought it was strange that all I got in response was "call us about this" until I actually did. He wanted to interview me about my real needs. I
I would just stay with Eric at Vulcan performance. He will give you a fair shake for the things he knows is best. Such as a new PSG board on the VP44. He won't sell anything that has the least bit of
Ok, in order of what you've been doing... back to front. Need to verify good fuel flow to VP. Does the tank have fuel in it? The banjo on the VP 44 is a good place to check this, though it sounds l
Merging onto highway, truck running just fine. Get to 55-60ish and sudden loss of power, not decreased, nothing. Rpms looked ok, think i hit it to see if it revved, but now I cant remember if it did. I remember thinking that i just lost my trans. But in tbe dame moment my engine was dead. I was only trying to stay safe and no longer diagnose. As i coastef up different offramp, i had it in N and tried to start.cranked but no start.
Stopped it, i turn key on,i hear a motor upfront. Try to start. Engine cranks, but doesnt start. W key on, i am reading no oil presure on OEM gauge. Well, needle just comes up a little but is still touching red zero line.
Oil seems ok, trans fluid seems ok, adiator is cool and full of coolant and temp gauge says 140. When I turn key off then on, i dont hear any motors in the rear like a fuel pump.
Ideas? Did my Fuel pump give up? Vp44?
I have basically zero tools. I would have to go home. I do have my OBDLink MX and phone. But I dont seem able to get the codes off it usong turbo. I will even take help w that. I think i have the obd software on here, but jave to go look. LG G2 phoneand have turbo free on it.
Currently sitting safe at a gas station 3 blocks or so fromw where i stopped. Had my chains and a couple guys pulled me here.
