- Replies 8
- Views 2.2k
dodgedieselnewbie 3 posts
ebbtide357 1 post
Buzzinhalfdozen 1 post
CTcummins24V 1 post
It sounds like you have a bad brake hose (soft line) in the front. Basically the hose will swell up on the inside and hold pressure inside the caliper causing the brake to drag. Or a bad hose won't al
DDN, Check the backing plates!! There are 3 or 4 points per pad, where the backing plate supports the Shoe. (If you think about it, this is what resists the springs that hold the shoe to
When I bought my truck previous owner installed new calipers to hopefully fix a problem with the front passenger side wearing down quicker.I have since replaced all the hard brake lines and installed new pads. It seems there is still a problem with the right side. Symptoms are twice the amount of brake dust on that side.. the warmer the brakes get it starts to squeal. . There is is an ever so slight pull to that side at times.. and the brakes seem to become more grabby the warmer they get. Im also starting to feel a slight pulsation like the rotor is slightly warped. The only thing I can think of would be to change the soft lines.. right? Anything else I should look at/for? Thanks...
