- Replies 15
- Views 7.2k
angus 6 posts
Mopar1973Man 5 posts
Me78569 3 posts
Dynamic 1 post
The most common cause for this is a failed torque converter clutch, but on rare occasion, I do see a stuck switch valve in the valve body. If the transmission upshifts and downshifts normally (aside f
As for governor pressure sensor and solenoid. If the transmission is launching in 2nd gear if in Drive. If you place it in 2nd gear it should down shift to 1st and then launch. I will advise that if t
This might help....
My Son owns a 2000 3500 DRW with a 47RE. He has been experiencing occasional symptoms of a governor pressure solenoid failure. He has not been driving the truck much lately, and has been waiting for the opportunity to get under there and replace the governor and related parts.
He drove the truck yesterday, and now a new issue has come up. The Torque converter appears to be locked and will stall the truck when he tries to come to a stop. He managed to get the truck home by putting the truck in neutral and dropping it in or out of gear when he had to stop.
I have never heard of a lockup issue quite like this one... Any comments or suggestions would be much appreciated.
