- Replies 5
- Views 2.7k
Mopar1973Man 1 post
dripley 1 post
hex0rz 1 post
Buzzinhalfdozen 1 post
Since the weather has been warming back up, I have forgotten that I still have a problem with the truck cranking because of air in the fuel system. I think I'm convinced that the fuel lines supplied to me from AD are now dry cracking and allowing air into the system. I recently discovered fuel leaking from the top of the tank. Something I think is attributed to cracked fuel lines under pressure... It does not leave puddles, but it does drip occasionally.
Any thoughts?
I'm thinking I might want to redo the line with something else, but dunno what. I also have the JIC(IIRC) fittings, which would need to go or I have to retrofit everything... This makes me sad...
