- Replies 25
- Views 6.1k
Mopar1973Man 5 posts
notlimah 5 posts
TFaoro 4 posts
dripley 2 posts
This is why I always leave the thermostat out till I get the block right to the edge of the thermostat. That way all air is forced out and you drop in the thermostat and bolt it down and hook up your
Have you done Mikes crankcase vent relocation Mod???? The OEM vent spews oily vapor that gets stuck to the cooling fins on the radiator, which attracts everything else (dust, pollen, dog hair, cattai
Why not do the easy thing and leave the thermostat out till the block is completely filled right to the edge of the block. Now install the thermostat and finish filling. Never have an air issue then.
Hey guys, so since I've had my truck for a bit the engine temps are acting a bit weird. I know it's normal to climb up to around 200F before the thermostat opens, but mine seems to be doing it sporadically after the thermostat opens. For instance, driving home there was a bit of a grade for about a mile, and the temps climbed up to 208. The fan kicked on and it cooled back down. Then today, I was driving for 30 min or so and it was at 193, where it usually sits. Then out of the blue it climbed to 202 and sat there until the fan kicked on and it cooled back down. Ambient temps were both around 65*. I'm thinking thermostat, but it didn't do this before the new water pump.
