NV 5600 rear output seal and bushing R&R
- Replies 12
- Views 8.3k
Ironforger 4 posts
klcammie 2 posts
Dieselfuture 2 posts
IBMobile 1 post
Ok, so I feel like I got burned by a cheap made in tiwan SKF output seal.
Synopsis of my issue:
02 4x2 quad cab nv 5600 217,000k
Tranny output seal started leaking and I had one bad u joint. All original equipment so I guess it's no surprise. So I figured I'll just do everything, new output shaft seal, all new u-joints and center bearing, change the trans lube & install trans Quad 4x4 filter kit as well as a 1/8" weld bung on the drivers side pto cover for a temp probe.
Did all of the above, took for a 3 mile test drive & the output seal failed - popped out. Luckily didn't drive to far so I didn't lose all of the trans lube. Still quite a mess though.
So I started thinking, where did I go wrong? The old seal was a major pita to get out, but the new one seemed to go in easy. Maybe too easy. The new seal was skf, old one was OEM. Never had an issue with SKF before. I always thought they were top of the line. After the fail I looked at the skf box - made in taiwan. I got it from rockauto. I usually try to avoid cheap parts but I Never gave this one a second thought assuming skf stuff is good. In hindsight the skf is slightly different from oem - should have red flagged it there.
Ok, so I'm not going to waste any more time. I'm getting an oem seal but I'm wondering if I should take the extra step & replace the nv5600 rear output bushing? Cant help wondering if a worn bushing could contribute to the previous seal fail.
Any suggestions or advice on changing out the output bushing? What are the symptoms of a worn bushing? Leaky seal? I don't have any vibration happening etc. I know that the trans rear output housing must be removed to R&R the bushing, figure I could support the trans with a jack, I don't' see a need to remove the trans do do this.
Thanks
