Power Steering Fluid Leak
- Replies 109
- Views 25.2k
leathermaneod 53 posts
Mopar1973Man 28 posts
notlimah 8 posts
IBMobile 7 posts
I just did mine with a rebuilt unit from advanced (A1 Cardone); unit has a low howl when underload. I need to contact them and see what my options are. BTW do yourself a favor and pull the ps/vacuum
Reservoir on the pump is sealed by an o-ring. Look at the front side of the pump and see if its leaking from the o-ring.
This ^^^ There is a large oring... you can replace this if leaking. But $50 .....might be worth a new unit .
Hi all,
Well I mentioned in my thread about injectors that it was finally time to re seal my vac pump because it had started really leaking. Seems I was wrong about the source of these new, and very sudden large puddles. Its PS fluid, and I can't figure out why, or where its coming from. Heres whats happened lately. Flushed PS fluid a couple months ago. Next, flushed fluid again to replace hydrobooster. At this point I was leaving drips, not puddles, from all the residual PS fluid all over the place from the two flushes. Next, I washed the underside of the truck to make sure I wasn't having major oil leaks. I went about a week seeing only a drip or two and sometimes nothing on the ground. All of a sudden I have large, very wet spots on the ground after sitting just a few hours. I thought it was the vac pump finally letting loose, but today I noticed that the fluid looked really light in color for engine oil. I got under to look and everything is a mess of course, but I can tell it is definitely my nice clean ps fluid, mixed with a little oil. The strangest thing is, everything is SOAKED, and even having not run the truck since yesterday afternoon, its still dripping every few minutes! There is literally fluid laying on the asphalt that hasn't soaked in yet, thats how fast its still leaking. Other weird thing is, the reservoir isn't really low
Where could this fluid be coming from? It definitely does not seem to be coming from any of the lines on the back of the PS pump. However, there are drips hanging off the bottom seam of the PS pump, it looks wet in between the PS pump and vac pump, but that could be oil. There is also PS fluid all over the top of the gear box which wasn't leaking much, if at all before. I do have a new return line from the gear box to the PS pump though, but even if that new line were loose(no i didnt check yet) that couldn't be the cause, because how would fluid get up and back to the bottom of the PS pump? Could the PS pump be leaking from where the shaft that drives it comes out? Is it re sealable or does it need to be replaced? I'm planning to go to the carwash later and spray it off and then watch for leaks, but any thoughts in the meantime? I have my vac pump reseal kit on the way and Id like to tackle that next weekend. Just trying to figure out if i should be ordering a new PS pump for the same time....
Thanks in advance for any and all help!
