Steering upgrade
Hey guys looking to put new steering links on the truck. Ever since I put the DOR track bar on my stock steering linkage has really shown its wear. It'll pop while turning and you can easily turn them by hand. Looking to upgrade to the 09 kit, will this one work?
https://www.amazon.com/gp/product/B0046NUOLM/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Also would it be worth upgrading the steering stabilizer? Or will that even work?
  • Replies 173
  • Views 37.1k
  • For those who see this thread and do some off-roading, I would definitely recommend having some sort of leveling kit or cutting the stud off of pitman arm joint. On a stock height truck, a couple inch
  • BIG-BLACK-DODGE
    BIG-BLACK-DODGE
    Ha yes we have good alcohol. Was a teenager playing Hockey in the States we would always find it funny how the U.S boys got drunk so fast... Lol our booze was definately more potent i think. The beer
  • notlimah
    notlimah
    Measuring now and then comparing that to what it is once the kits in would work. I eyeballed mine just to get it pretty straight and drivable but am getting it aligned by a shop this afternoon.
Ok so was just doing some more research on this. I broke it down by our bolt pattern and it looks like the only two offsets available for this wheel that'll fit on our truck is either an offset of -6 or 12 with backspacing at 4.25in or 5in respectfully. I think either way with at least 4in of backspacing I should be fine.
On 6/24/2016 at 5:10 PM, notlimah said:
From the looks of them, I'm not sure how they'd be replaced individually as they seem sealed. I doubt replacing the whole tie rod is that expensive. You might be able to grind off the sealed looking end or just whack the threaded end to knock it out of the tie rod, but this is all speculation.
@CTcummins24V What back spacing does your 16's have?
4.5" backspacing, 0 offset
Do you guys know what the backspace and offset numbers are for the stock alloy wheels?
Thanks for that @CTcummins24V visually I think mine looks fairly similar in spacing but we'll see once I attempt to mount it.
@leathermaneod not sure on those numbers off the top of my head. I tried google and it gives a lot of different answers.
measuring mine I came up with 6.5" on backset and I read that the stock wheels are +44 mm offset. Mine are the stock alloy wheels.
Something like 5.5"-6".
Oops didn't see Dripleys reply
Edited by CTcummins24V
CT do you have stock alloy wheels?
Edited by Royal Squire
While I still have the stock alloy wheels on mine they are for the 265's and not the 245's. Mine are 16 X 8 but I am not sure if the wheels differ in size for the 245's.
I was attempting to read through the CF thread I posted earlier and it seems like people have been able to run this setup on OEM wheels, but they had to grind down the thread side of the TRE in order to get them to fit at full lock. Most said they ground it down an 1/8th of an inch or so, so obviously that's not much, but I have no first hand experience in this.
I'm just hoping this will fit on my truck without having to do too much modifying.
Unless your wheels are totally different from what I am thinking, it sounds like you should be fine. I am definitely going to give it a try with my stock alloys.
I just ordered the kit today and it'll be installed tonight. I have a 2002 RAM 2500 4x4 Diesel with Skyjacker 2" soft ride leveling springs and bilstien shocks.
aftermarket 16" wheels ( not sure on the back spacing)
has 35" duratracks and driving this truck i'm sure I look like a scene from the Dukes of Hazard where the steering wheel is going back and forth just to keep the vehicle straight! Lol
l new xrf ball joints, new wheel bearings ranch steering stabilizer etc. No play in my TRE's but they are easyvto move by hand.
 I have read a ton of literature on the swap and I was convinced but then I thought I started reading something about people were backing up and snapping tie rod ends off ???  I couldn't pinpoint if this was from a bad tire rod that Mopar how to change up number for or what ???  Anyway I'm going to give it a try and watch it like a hawk and I'll report back with my findings.
 I heard guys saying that they even leave their steering stabilizer off because it actually seems better ????  I will leave it off at first and try it and then I will instal it and give honest feedback .  I am in Alberta Canada right in the Rocky Mountains so I have every type of terrain to try it in as well as smooth hwy's.
 Looking forward to hearing the OP's  findings with this as well.
 The kit I ordered was part number 52122362AL from Dodge. I think they have Ah Al etc but i have the newest updated part number. Will report back shortly.
Edited by BIG-BLACK-DODGE
Looking forward to your findings!
I remember reading about the snapping of TREs as well, but from what I understood it was happening because people were installing them and not lining up all the tie rods and tie rod ends so when it got turned full lock one way or another, it would be at a sharp angle with lots of pressure (exactly how it's not supposed to be) and snap off. That's what I gathered from it, but that link I posted earlier in this thread is a beast so I haven't made it all the way through!
Looking at my stock wheels there is so little clearance for the stock set up that I believe the T steering would be a problem. Zero* offset wheels should off set that problem. Larger diameter wheels would accomplish the same thing.
@dripley If you look at my pic I posted earlier in this thread, does it look like my wheels have more room then yours? Is it mainly the TRE threads that don't have room or the actual tie rod ends that barely fit?
A lot more room than mine. I will get a pic and post it later. Bet I dont have a quarter inch of clearance for the top of the TRE or the bottom of the TRE.
From reading the CF thread it sounds like you can get enough room by cutting off some of the "nut" on the top end of the TRE stud....
@dripley That's good to hear. I feel like these should go in easy-peasey then!
@leathermaneod That sounds like a little too much grinding to get these to fit IMO!
I didn't see his post. What number post was it? Easier to find that way
