New toy!! Could use some pointers from the hotrodders
- Replies 18
- Views 4.4k
Wild and Free 5 posts
Mopar1973Man 4 posts
CSM 3 posts
01cummins4ever 3 posts
No idea on compatibility. I am a mopar guy. For ignition, it depends on how much work you want to do. MSD is the best, but the factory system is likely just fine with some parts added.
the turbo 350 trans can be built to handle about 500 hp. but then agian so can a 700R4. it's should be a bolt in replacement. as for parts get them for the engine year not car year. as
Small block chevy will pretty much bolt directly in place of the olds engine no issue with trans, Go with a 600 cfm Edelbrock carb for a mild small block and it will be perfect. Factory Hei ignition w
So I am getting a new project added to the rest of them. My old man is giving up a 1978 Olds Cutlass Supreme. Car is in pretty good shape apart from its been sitting for the last 20 years. I have a mild Chevy 350 small block to put in it. 1st gen block, corvette 2.02 heads, Edlebrock high-rise intake, mild cam, etc. I have a couple things I could use some help on if there is anyone with experience in the area.
First off, the car still has the factory Olds small block V8 in it. Skipped a couple teeth on the timing chain and dont really want to mess with it. Is there a problem with taking the Olds out and putting the Chevy in? Will the motor mounts and accessories and stuff go back on easily? Will the transmission bolt up?
Next, I would like to go with some kind of a performance ignition system including distributor, coil, module, etc. What brand would you guys go with? MSD? Mallory? And... When I do get the system, do I get it to match the car? Or the engine?
On an engine set up like this, what size carb should I start with? 700CFM? I am not sure how much this thing is going to flow or how much fuel it will need. The car will just be a street car and daily driver type.
I am sure I will have more questions but this will get me started.
Thanks!!
