- Replies 26
- Views 8.2k
leathermaneod 8 posts
Mopar1973Man 7 posts
TFaoro 5 posts
KATOOM 3 posts
Popular Days
This is the sealant I use on most applications. I've even made an oil pan gasket with it on a Mitsubishi engine I was over hauling, it never leaked.
Magnet is on the PTO cover on one side. Just pull covers off and wipe it clean. Pretty simple.
Ultra Grey or Ultra Black. I "believe" the grey is slightly more oil resistant but not positive as I've used both with positive results. Get a couple cans of brake cleaner, NOT carb clean
Hi all,
My NV4500's pto covers are leaking fluid so I'm planning to pull them and reseal them. I'm looking for suggestions on what type of rtv to use and how best to clean out the case of the trans while I have them off? Also, any opinions on wether or not a filter is worth the money? They kits are $100 from quad, seems like a good idea but I'm not sure if it's a gimmick or not? Also I've heard there should be a magnet somewhere in the case and that I need to clean it off? Where is that? Should I add anymore magnets? What type? Sorry for all the questions, just want to be prepared.
Thanks!
