Trailer connector wiring
- Replies 50
- Views 13k
leathermaneod 18 posts
Wild and Free 7 posts
IBMobile 6 posts
notlimah 6 posts
http://www.delcity.net/store/Heat-Shrink,-Solder-&-Crimp-Butt-Connectors/p_805407.h_801820.t_1 Dunno if you have used those, but it makes life nice
To be honest I don't even look at the prices, just grab em when I need them and go about my job cause I want it done right not cheap so I never have to worry about it again. For a few bucks the l
The 12V+ power supply is battery power and hot all the time on all trailer plugs so it is correct. Can't tell you how many fuses I have blown when accidentally touching 2 terminals together in th
Hi all,
So I want to replace my trailer connector plug and clean up this wiring.
Now just throwing on a new plug would be no big deal, but I want to figure all this out and clean it up. I know that whole bunch of wires thats hanging on the right was installed to run up to the bed for a gooseneck connector. Im planning to leave that as is because I may pull a gooseneck in the future, unless someone can suggest a better way of wiring that?
What I don't know is, what is that short white wire up at the top thats capped off, and what should I do with it?
What is the long black wire thats capped off?
What is the lighter gauge wire with the red one attached and capped off in the center of the picture? And why would someone have put that red one on there? I believe the main wire is blue with a black tracer.
My truck does have a trailer tow package from the factory.
Also, would you guys use crimp on eyelets like that? or just strip the wires and put them in between the two little plates and crush them with the screw as designed?
I spent a little time looking at the fsm, but I'm not real good at interpreting schematics like that and it didn't make much sense...
Thank in advance all!
EDIT:
Well this fsm is making a little more sense now, still haven't found the answers to any of my questions though.
I also think I will remove those huge crimp on connectors for the gooseneck wiring, and solder and heatshrink them in. Question on that though, shouldn't the wiring for the gooseneck have 7 wires? It only has 6 now so I'm thinking one is missing. Maybe thats originally where the red one went thats on the blue wire?
EDIT 2: So it sounds like the black wire is probably a second ground, but I still can't find anything on that short white wire. The only white one I see in the FSM is further up with the brakes, but it doesn't seem like that could be the one here...
Edited by leathermaneod
