@Mopar1973Man OBDLink Questions
- Replies 13
- Views 3.4k
Mopar1973Man 5 posts
Me78569 5 posts
AH64ID 3 posts
Popular Days
We can't begin to guess how the software people wrote the calculations so sometimes you need to fudge the needs until they result in something that makes sense. I had to do the exac
using the limited sensor data we have calculating MPG on a turbo diesel is tough. That is why we always verify with hand numbers if you are really wanting to be accurate. The quest
I was just looking at your article on the OBDLink and have a couple questions.
You say it gets fuel flow from boost; however, fuel flow at 10 psi and 1500 rpms is a lot different than 10 psi and 2500 rpms. Also 10 psi at 12° of timing is going to be different fuel flow than 10 psi at 8° of timing.
So how accurate is it?
What did the SGII use for fuel flow calculations?
Your definition, and how to calculate, volumetric efficiency is based on your fuel tank yet volumetric efficiency has nothing to do with a fuel tank. Forced induction motors often have volumetric efficiency of over 90%. 63% sounds like a 5.9L gas Dodge Ram...again it has nothing to do with your fuel tank, but rather the amount of air an engine moves versus its displacement. What you described is how to calibrate the fuel consumption.
As for BSFC it's going to vary with each and every timing adjustment, duration adjustment, injector change, turbo change, etc. It's not a fixed number, so are you re-adusting for each mod and each retune? Aside from hours of dyno time I am not even sure how you would re-adjust BSFC.
Or is the OBDLink a wide shotgun blast at what your getting and not really useful in terms of hp or fuel flow?
Edited by AH64ID
