HX35/40 Turbo rebuild kits
Any good sources for a HX35/40 rebuild kits out there? I need a bearing kit for the current turbo I've got in the shop. Anyone know of good bearing kits for a fair price speak up and drop a link please.
  • Replies 22
  • Views 7.7k
    I'll most likely jump on that so I can rebuild this HX35/40 turbo and get it on the truck.
  • Buddy just bought one from here. Told him to make sure it's genuine holset, and it is.    https://www.amazon.com/Genuine-Holset-Cummins-Turbo-Rebuild/dp/B00M9NJ1VK
  • leathermaneod
    leathermaneod
    Tyler how were you able to tell it was genuine Holset? Just curious because the reviews don't exactly make it seem like a sure thing....not doubting you, just curious and also wondering if the seller
Anything over 125% is hitting the limit.  150 does squat.
At 20 psi the ECM is commanding 3700 at peak. Add %125 to it and you have the max of 4095
Mike all I changed on the tune was the low limit for wiretap.  The rest was the same.
Mike just needs bigger injectors :shifty:
I got my kit from BAE.  It seemed to be good quality and is still working fine.
