- Replies 17
- Views 4k
Dieselfuture 7 posts
Mopar1973Man 3 posts
dripley 3 posts
IBMobile 2 posts
It's most likely the park switch in the wiper motor is going bad.
The controls are in the multi-function switch yes... The actual delay part is part of the central timer. Here you go...
All the wiper transmissions I come across have a plastic bushing in them. Any grease you put in there will dry out in a year or less, collect dust and grit causing a possible premature failure of the
Has any of you had this problem? My wipers don't park back to normal position after using washer fluid function, and also the intermittent selection malfunction sometime. I'll set it to low speed but it will almost be on high and sometimes ok. And for the wipers to be at park position, I have to catch them at that point and shut the switch off. I had similar problem happen on a different vehicle and after changing wiper control on steering wheel it didn't help and ended up being a wiper motor. Where should I look first? Thank you.
