- Replies 6
- Views 2.4k
Mopar1973Man 1 post
dripley 1 post
IBMobile 1 post
DocH 1 post
Popular Days
I did a good bit of digging into this a month ago when I flushed my coolant. Sure I could have spend all the money on fancy HOAT coolant, but why when the factory fill is plain old green from Napa and
I replace about one radiator a month. Every one is due to a leak in the area of the radiator where the hot water from the engine comes into it. Either the seal between the aluminum core and plastic
Correction. Not acidic, but basic... Still corrosive though. I'll have to agree that most people do not change coolant often enough and end up getting a offset pH number and turns corrosive eating eve
While researching which coolant to use after new radiator install, I found the following:
http://www.turbodieselregister.com/tdrarticles/tdrarticle62_antifreeze.html
About halfway down the page there is this table:
There seem to be a few interesting tidbits in the article, and ALL sorts of talk about silicates etc...
Thanks for looking, and I am very curious as to what Folks think of the info....
Ed
