- Replies 11
- Views 2.7k
Wild and Free 3 posts
leathermaneod 3 posts
dripley 2 posts
TFaoro 1 post
Hey guys,
My dad has an 03 2500 ext cab lb with a hemi, yuck! lol anyway, he was asking me if I knew anything about what fluid he needs for his diffs. I only know what I read over on CF and that is that it should have an AAM axle with gear driven limited slip, if it even is limited slip, and so should not need any LS additive. He said he could find any identifying info on the axle sonintold him to ask the dealer. He did and they told him his truck does have a LS rear and that he does need fluid with LS additive. Does that sound right? I though all 3rd gens have AAM axles which have gear driven LS and so don't need the additive? They didn't tell home what axle he has. He said they didn't seem too knowledgeable. Can someone set me straight here?
Also, do you have to be careful with running the exact same tires with a gear driven LS like you do on the 2nd gens?
And can you safely run two different tires on the front axle of a 3rd gen?
Thanks guys!
Any help is much appreciated and I trust you all way more than I trust CF or the dealer lol.
