Sputtering - Edge Comp related?
- Replies 8
- Views 2k
dodgedieselnewbie 3 posts
Dieselfuture 2 posts
TFaoro 1 post
Me78569 1 post
Popular Days
Start with the easy stuff. Take the smarty off and leave the edge alone. Then take the edge off and leave the smarty on. If it's gone on both of those the programmers are fighting ab
Have you driven in this same manner before? IE loaded with a camper at those speeds on the same types of roads? IE is the possible that this issue has always been there, but you ha
Thanks for your reply... I did check the alternator (which is new as of a couple months ago) for AC noise.. and all is well there. There are no other symptoms that suggest it is AC noise. I'm going to
I think something is wrong with my Edge... This past weekend I took a trip up to Connecticut with the camper. Under normal acceleration and driving I don't notice a problem.. but when I'm up around 65 mph and I try to accelerate up a grade I can feel the truck sputter a bit. I turned off the Edge and the problem went away. I was running the Edge on 2/3 and my Smarty is set to 2. Is the Edge starting to fail? I haven't checked for codes yet...
Edited by dodgedieselnewbie
