- Replies 14
- Views 3k
Mopar1973Man 4 posts
dripley 4 posts
fuze24v 4 posts
notlimah 1 post
so let me begin with this, this all started when i decided to install some DAP 75hp injectors, ( im pretty sure anyway) so awhile back, i posted something about my fuel filter canister leaking which was creating a fuel/air leak, i would surge at first startup. I replaced the canister, all seemed good since then, but i haven't really drove it that much since replacing it, ( I also after i installed the injectors the first time( wrong, i did it backwards and realized it after i got done talking to Mike,) went back through a second time and checked all the o-rings on the injectors, o-rings and crossover tubs, all checked out. still did the same thing after i put it all back together. so then i dug into all fuel lines, From the raptor pump up to the injectors, one was slightly lose but nothing bad!! i was thinking yes!!! and then again no!! same thing, surge after startup.) so from then to now, this is where i am at.
I just got back from my honeymoon last night, about 1 in the morning, tired, cold and grumpy, i left my diesel at my wife's parents house so they could watch it. we were gone for 12 days!!!
I go to start it up after we get to it, nothing....... just cranks..... you have to be f******** kiding me! 1am in the freaking morning!!! with rain!!! Fuel PSI 18* everything checks out, crack the injectors line...... wait a little while..... sputters up.... closed the lines and is all good now......
So where the hell could i be getting air from?? the only things that leads me to believe that could be wrong is the injectors?? or the raptor pump?? im lost in my own ideas because i have been through everything x3 now and still cant figure it out! should i send the injectors back to DAP to get the, checked out??
Sorry about the rant,
Thanks nate!
