High fuel pressure. AirDog whining.
- Replies 10
- Views 2.6k
Popular Days
DONT adjust that valve.....! Not sure why anyone thought this was a good idea to market. Matter of fact, I'd suggest throwing it away and replacing with a factory Bosch overflow valve thats NOT adj
Agreed. I would go back to Bosch OE overflow valve. The never fail I've got 12 years on mine and 220k miles still going fine. The fuel pressure of the AirDog is the important thing than overflow valve
Yes, different topic. I'll look for that thread.
I recently got my much needed gauges and hooked up fuel pressure first to check things out. When i bumped the starter for the 25 second run, it jumped to 24 and slowly increased all the way up to 26! Does this sound like a return line restriction? I have an adjustable overflow valve that is preset at 14 psi. What could be going on here? I think this is the cause of my rough running truck...
