Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 337.2k
  • Quadzilla Power
    Quadzilla Power
Yes tc is unlocked. You can hear it fueling on and off. It's something to do with the wiretap. It dosen't do it in canbus lvls.
If it matters there was a tap already on the wire for the vp from a previous tuner. I left it there and tapped beside it for the quad. With that being said it did not behave this way when I had the adr2_comp tune flashed.
man that's strange.
Things that wiretap looks at
Boost, RPM, TPs  do you have a data log to compare that video to?
I attached a data log file in a couple of post back. I don't see anything out of the ordinary besides my fuel pressure. I have an auto meter sending unit, that's why the numbers bounce around. My glowshit fp gauge reads a steady 16-17psi.
In the video I am holding steady throttle when the rpm gauge is dancing.
Thanks a TON for the data log.  You can see whats going on pretty quickly in the data log.
Scroll down and watch where you go to steady state ~%40 - %50 throttleCapture.PNG
Look at your map readings, they are falling to 0 psi.  Remember from 0-16 psi the Quadzilla is reading PSI from the ECM directly so the ECM is saying that you are getting 11 psi then 0 psi on the next read.
this is the cause of your surging.  Your map readings are not stable.   I would check your map wiring  VERY closely.  Check for good stable 5v signal to the map sensor.
Edited by Me78569
Thank you!
I will look into it and see what I find.
No problem bud.
I would guess bad connection / wiring OR a failing map sensor.  Prob the map wiring to the ecm for shorts, ensure you have good ground and 5v signal.
Since the older tunes don't do this I would expect your issue to be between the Quadzilla map output and the ecm.
My Mods
My Tunes
DD:
Tow:
Race:
Hey me78569 can you email me
Edited by Jay1clark
I'd rather keep stuff visible so others can benifit from any issues / complaints / leanring
On 3/27/2017 at 3:16 PM, Me78569 said:
No problem bud.
Just to update my problems.
I check the MAP wiring and didn't find any flaws. Check for power (4.9V) and everything looked good.
Flashed the old COMP tune and now the MAP sensor is reading good through my iquad. With the V2 i could actually watch the boost pressure drop on the iquad. Im stumped.
With that being said, i will try the V2 flash again and see what happens. It won't be until next week bc i am traveling this weekend.
Also already ordered a new MAP sensor. Don't think this will help the situation but we'll see.
Any input would be great appreciated.
Thanks,
iQuad-2017-03-29-07.06.441687763203.csv
The difference between the V1 tunes and the V2 tunes is the V2 tunes read Map from the ecm until 16 psi.  V1 tunes read PSI from the voltage of the sensor directly.  Issue with that is there is not really smoothing place needed to make the V2 be smooth.
So those drop out in the data log are literally the ECM sending 0 psi across the canbus.    Something funky is going on in the map reading / ecm.
The communication is like follows
sub 16 psi
Quote
Quadzilla: Hey ECM whats PSI?
ECM: PSI = x psi
Quadzilla: great I will show that psi on the screen.
also looking at the data log I see the same issue, I see %30 jumps in Map sensor readings wihtout change in load or TPS.  example Lines 15 && 16 show 0 % tps and 6 psi boost.   line 37 show 3 psi 0 tps.  lines 100-134 show a %30 jump in map back and forth stable TPS.
Edited by Me78569
Thanks for the quick reply
My ecm is "lazy", it takes some time to wait to start. Hopefully it's not on it's way out and the new map sensor fixes the issue.
thanks again guys
thanks again guys
tell tail sign of the ecm memory doing hte way of the buffalo.
The WTS light is the light to show that the ecm is turning on. Think of the WTS light as
       Had some time this weekend to play with a racing tune. Over all it worked well I though, some to minimal smoke and good power. Although I had my Boost defuel set at 37psi and EGT at 1300, data logging said I was at 49psi and 1500 egt. I may reduce it to 32 and 1100 and see how it defuels.
       Not sure how my HX35W is pushing 50psi of boost and making power, I though they were good to maybe 35-40psi. Maybe PO turned it to a hybrid:think: I’m running 60hp SAC injectors. I’m sure there is tweaking that can be done to make it better, but you can definitely tell the difference between daily drive tune and economy tune.Take notice of (Pump Low Boost Scale PSI: 8 PSI vs BOOST LEVEL FUELING - CAN BUS)
      Also below ill post a Towing tune that I think may work for my application see what you guy’s think and if I should adjust any of it. Or any of theses tunes for that matter, Thanks.
I was on level 6 for race tune, Towing tune I will probably stay at level 3 for most part, but will try level 6 also.
Race Tune
TUNE PARAMETERS
Number of Power levels:  6
RPM Limit:  3400
VALET MODE PARAMETERS
Maximum Valet Mode Power:  15%
PUMP TAP PARAMETERS
Maximum Fuel Stretch: 2000 microseconds
TPS Pump Maximum: 80%
TPS Pump Minimum: 10%
Minimum Pump Tap Fueling Percentage: 20%
Boost Scaling: 30 PSI
TIMING PARAMETERS
Fuel Load Timing: 2*
Low PSI Timing Reduct: 4*
Timing Reduct Scaling: 80%
Light Throttle Timing Adv: 3
RPM TIMING MAX
1500 RPM: 16.5
2000 RPM: 19
2500 RPM: 22
3000 RPM: 24
Max: 25
PSI:105
PSI:107
PSI:109
PSI:111
PSI:114
PSI:116
PSI:118
PSI:121
PSI:122
PSI:123
10 PSI:124
11 PSI:127
12 PSI:130
13 PSI:135
14 PSI:139
15 PSI:143
16 PSI:150
18 PSI:150
20 PSI:150
22 PSI:150
24 PSI:150
26 PSI:150
28 PSI:150
30 PSI:150
Tow Tune
TUNE PARAMETERS
RPM Limit:  3200
PUMP TAP PARAMETERS
Maximum Fuel Stretch: 1400 microseconds
TPS Pump Maximum: 100%
TPS Pump Minimum: 20%
Minimum Pump Tap Fueling Percentage: 5%
Pump Low Boost Scale PSI: 12 PSI
Boost Scaling: 40 PSI
TIMING PARAMETERS
Low PSI Timing Reduct: 3*
Timing Reduct Scaling: 100%
RPM TIMING MAX
1500 RPM: 16
2000 RPM: 18
2500 RPM: 20
3000 RPM: 22
Max: 24
PSI:104
PSI:106
PSI:108
PSI:110
PSI:112
PSI:114
PSI:116
PSI:119
PSI:121
PSI:123
10 PSI:126
11 PSI:128
12 PSI:130
13 PSI:133
14 PSI:135
15 PSI:138
16 PSI:140
18 PSI:146
20 PSI:150
22 PSI:150
24 PSI:150
26 PSI:150
28 PSI:150
30 PSI:150
Edited by Me78569
Does anyone think 50 psi is normal to see with an hx35w,  or is it about to blow up at that psi.
Uh that's bad.  Those are at risk of blowing up around 37-40 psi....
Edited by trreed
I would want you to verify with a mech gauge,
the high psi you get on the oem sensor the less accurate it is.  the hx35 is good to ~38 psi  beyond that, hot air.
My iss pro mechanical gauge also showed close to 50, i ether have a hybrid or I got lucky and it didn't blow up.
oo yea,  even a hybrid is out of it's map lol.
tune down the fuel some.
Can you post a pic of the turbo, specifically the compressor cover and how the wastegate is run?
