Quadzilla V2 Custom Tunes
Quote
Power Levels:
Timing
Fuel Load Timing:
Low PSI Timing Reduct:
Timing Reduct Scaling:
Light Throttle Timing Adv:
Timing vs rpm
1500:
2000:
2500:
3000:
Timing Max:
Wiretap
Pump Stretch:
TPS Pump max:
TPS Pump Min
Pump Low Boost Scale PSI
Boost Scaling:
RPM Limit:
Power Reduction:
0 PSI %:
1 PSI %:
2 PSI %:
3 PSI %:
4 PSI %:
5 PSI %:
6 PSI %:
7 PSI %:
8 PSI %:
9 PSI %:
10 PSI %:
11 PSI %:
12 PSI %:
13 PSI %:
14 PSI %:
15 PSI %:
16 PSI %:
18 PSI %:
20 PSI %:
22 PSI %:
24 PSI %:
26 PSI %:
28 PSI %:
30 PSI %:
My Mods
My Tunes
DD:
Quote
Power Levels: 6
Fuel Load Timing: 2
Low PSI Timing Reduct: 2
Timing Reduct Scaling: 100
Light Throttle Timing Adv:2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Fuel Stretch: 1700
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 8
Boost Scaling: 40
RPM Limit: 3500
Power Reduction: 15
0 PSI %:84
1 PSI %:84
2 PSI %:85
3 PSI %:86
4 PSI %:87
5 PSI %:88
6 PSI %:89
7 PSI %:90
8 PSI %:92
9 PSI %:94
10 PSI %:96
11 PSI %:98
12 PSI %:100
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Tow:
Quote
Power Levels: 6
Fuel Load Timing: 1
Timing vs rpm
1500: 16
2000: 19
2500: 24
3000: 26
Timing Max: 27
Fuel Stretch: 1400
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 5
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:92
1 PSI %:92
2 PSI %:94
3 PSI %:96
4 PSI %:96
5 PSI %95
6 PSI %:95
7 PSI %:96
8 PSI %:97
9 PSI %:98
10 PSI %:99
11 PSI %:100
12 PSI %:102
13 PSI %:104
14 PSI %:108
15 PSI %:112
16 PSI %:116
17 PSI %:120
18 PSI %:124
20 PSI %:128
22 PSI %:132
24 PSI %:136
26 PSI %:138
28 PSI %:138
30 PSI %:138
Race:
Quote
Power Levels: 6
Fuel Load: 1.5
Low PSI Timing Reduct: 3
Timing Reduct Scaling:100
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Quote
Fuel Stretch: 1800
TPS Pump max: 100
TPS Pump Min 20
Boost Scaling: 40
RPM Limit: 3700
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Quote
Power Levels: 6
Fuel Load Timing: 2
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Scale PSI: 0
Boost Scaling: 40
RPM Limit: 3300
Power Reduction: 15
0 PSI %:94
1 PSI %:94
2 PSI %:95
3 PSI %:96
4 PSI %:97
5 PSI %:98
6 PSI %:99
7 PSI %:100
8 PSI %:102
9 PSI %:104
10 PSI %:106
11 PSI %:108
12 PSI %:110
13 PSI %:112
14 PSI %:114
15 PSI %:116
16 PSI %:118
17 PSI %:122
18 PSI %:126
20 PSI %:130
22 PSI %:134
24 PSI %:138
26 PSI %:138
28 PSI %:138
30 PSI %:138
Edited by Me78569
  • Replies 1k
  • Views 353.4k
  • Quadzilla Power
    Quadzilla Power
If you had the Contorl pod you are running V1 tunes, not V2 tunes.   The V2 tunes are smoother than the v1 tunes.
you can flash the box under the hood with the v2 base tune, but that is up to you.   I did a video covering the process.
If you want V1 tune suggestions create a new thread with that title and I can give you some pointers.
3 minutes ago, Fireman_51 said:
Alright. How do I flash it over?
After I get it flashed over. Do you have some customing tuning you would recommend? I don’t want to mess up anything. I don’t mind having smoke, but I also would like to have good/ decent mpg. With just the control pod on level 6 I had great mpg. That’s what I normally left it on.
I have been reading and lurking for last few days since I have got my brand new Adrenaline with v2 and have been playing around with the custom tuning. I'd like to see what you guys think of my tune.
My truck is a bit different from everybody else's because it weighs in at 10k+(welding rig with sa200 and custom flat bed) on an a daily basis.
TUNE PARAMETERS
Number of Power levels: 6
RPM Limit:3200
VALET MODE PARAMETERS
Maximum Valet Mode Power:35
PUMP TAP PARAMETERS
Maximum Fuel Stretch:1800
TPS Pump Maximum: 100
TPS Pump Minimum:0
Pump Low Boost Scale: 8psi
Boost Scaling:40
TIMING PARAMETERS
Fuel Load Timing:2
Low PSI Timing Reduct:3
Light Throttle Timing Adv:3
Light Throttle Timing Load Limit:30
RPM TIMING MAX
1500 RPM:14
2000 RPM:18
2500 RPM:22
3000 RPM:25
Max:26
BOOST LEVEL FUELING - CAN BUS
PSI:111
PSI:112
PSI:113
PSI:114
PSI:115
PSI:116
PSI:117
PSI:118
PSI:119
PSI:120
10 PSI:121
11 PSI:122
12 PSI:123
13 PSI:124
14 PSI:125
15 PSI:126
16 PSI:127
18 PSI:129
20 PSI:131
22 PSI:133
24 PSI:135
26 PSI:137
28 PSI:139
30 PSI:141
So what do you guys think?
The truck is a 2002 HO with a 6spd stock other than 4in turbo back with muffler, fass 150 set at 16psi and a valair 500hp Kevlar/ceramic towing clutch.
Truck is very clean but seams to be very sluggish down low. Also with my boost elbow all the way in I'm only seeing 30psi max boost if I'm really on the throttle.
Any help is much appreciated.
Double check your wire tap. You should be able to push over 35 PSI. I would steepen the fuel table more start out at about 105% and using a exponential calculator use a growth rate of about 3 to 3.5% that should get just enough lag to light the turbo and then pour on the fuel.
I'm running slightly more with +75 HP (7x0.0085) injectors and HX35/40 turbo I can just about light the tires up without tapping the pump. But you do have more weight. I've got to ask also are you running oversized tires possibly? This will make a huge impact on gearing and will make the truck struggle to pull the weight.
I'm running stock 235/85r16s with 3.55 gearing. I will step up to either 3.73s or 4.10s when I put on my 255/85r16s. I forgot to add the truck is a dual rear wheel.
Just to make sure I'm using this calculator, you plug in 105 for the initial then 1.03 for the increase then keep changing the time value up to the 30+ slot?
so the first few settings would be as follows:
0psi = 105
1psi = 106.08
2psi = 107.17
3psi = 108.28
4psi = 109.40
5psi = 110.52
Sorry im just trying to understand how to calculate the fueling curves.
I also noticed that isspro mechanical boost gauge does not match the boost numbers coming from the app. Does the tuner use the same value im seeing?
Edited by KMayborn
Additional info
I would run the stock injector daily tune I posted in the tune download section.
0psi = 105
1psi = 106.08
2psi = 107.17
3psi = 108.28
4psi = 109.40
5psi = 110.52
Yes the box under the hood sees the same boost you do.  The box under the hood reads boost from the ECM until 16 psi.
I woiuld just crank up canbus fueling at 0psi as high as you want until you run into smoke.  Then create the curve based on that.  Also take your Pump Low Boost Scale: setting down from 8 psi to 2ish.  That way you are getting wiretap sooner.
Edited by Me78569
If I drop the boost limit that low won't i be using wire tap pretty much anytime I'm accelerating? Also won't that kill mpg?
if I put them can bus at 115 I am still clean  off idle. Is that normal or should I atleast be hazing?
Wiretap is also related to TPS input so if you are leaving the light at light throttle then you wont be using much wiretap.    MPG while leaving a light is also VERY bad regardless lol.
If it's clean at %115 add another %5.  I can't speak to what is normal.  Are you going WOT leaving a light and it is still clean?
I'm leaving as hard as I can with out trying to slip the clutch. It's pretty agreessive and if I just stab the throttle I get a hiccup.
Add more fuel until you see a dark haze.  That should get you as much fuel as needed when you go WOT from a light.
I would try adding fuel to the canbus before wiretap.  Think of Wiretap as a way to fill the mid to high rpm lul that occurs on a stock truck.
Alright. I'll drop down to level 3 again and try to make it haze pretty good.
Is 19.5* timing at 1900-2000 rpm too much when cruising?
I would prefer you had studs, but I can say pretty much all tuners out there can get 19.5* of timing at 2000 rpm.    you will feel the truck being held back when timing is to far advanced.
In order to be safe with it, I would just ensure that timing gets pulled as soon as you increase fueling beyond cruise state.  Use the Light throttle load limit to control this. that % should be set ~%5 above your cruising load.  That will ensure that if you increase load timing will decrease and not risk damage to the headgasket
My truck likes that much timing at 2k rpm.  I ran that much timing for ALONG time on stock headbolts.
Since I posted earlier I have changed my timing settings to the following:
fuel load timing:2
Low psi timing reduct: 3
Timing reduct scaling :100%
light throttle timing adv: 1
light throttle timing limit: 35%
1500:16
2000:18
2500:22
3000:25
max: 26
should I pull throttle advance back to 0? It was my understanding that it's based off of 17* base timing so shouldn't 1 degree put me at 18 not 19.5? Is there someone I'm missing?
also headstuds will probably the next thing on the list since I plan on bigger injectors and turbo in the not to distant future.
Edited by KMayborn
timing advance is no longer base 17* it is on top of your rpm timing curve.
So you will get a max of 19* at 2k rpm
Got it. I'll run it on the way in to work tomorrow and see how it does. Thanks for the help guys. I'll report back tomorrow
Well, Its been a while since I checked this. We got TJs box in and did work with him even without knowing he posted this in the forum, so there is that.
Honestly, we don't know what happened to his box. It is definitely weird and not a normal failure mode thing.
Love all the help with the tunes by the way. You guys are great!
So did some testing today. To verify the pump tap was working I set all the can bus to 100, 2200 stretch,minimum pump tap to 50%, low boost to 0 and have get a rev in neutral. Gave me a big puff. So I'm pretty sure it's working.
I made two data logs today. One on the way into work and one on the way home. Couple things in noticed. Egts on the iquad are consistently 150 or more degrees hotter, boost pressure is consistsntly lower than my a pillar gauge by 3- 5 psi, and even with my timing setup in the following format I am still get 19 to19.75 degrees timing at less than 2000rpm. What gives? I'm not sure what I can do to bring the timing down.
Also, boost still makes out at 30 on my pillar gauge and 27 on my iquad.
Here are my data logs. I am limited to only my phone right now so I can open them. Could someone help me out with viewing them?
iQuad-2017-09-25-05.55.39.csv
iQuad-2017-09-25-06_55.28.csv
Edited by KMayborn
Whats your warmup temp sent to?
After 50 mph an addition 1* of timing gets tacked on to your light throttle timing to help support mpg.
Timing above 2000 is going ot ramp up very quickly with your curve being 22* at 2500 and 17 at 2k  it is going ot increase by 5* in those 500 rpm.
I think this is why you are seeing the timing above 19* in the 2k region.   Overall I am not worried about the timing as when you put your foot into it the timing drops a lot.
are you seeing any drivablity issues or just confused at to why timing is near 19* at 2k?
