How do I manually install The Quadzilla Driver / Load the Quadzilla V2 tune on Windows 10 / 8 / 7
  • Replies 85
  • Views 63k
  • I just want to say thank you. This was a long process for me to get this updated as I’m totally lost when it comes to using a computer but there has been a lot of time and effort into setting this up
  • What you do????     Also at this point I am fairly confiedent that you won't need to flash another tune in the near future, unless someone finds something big.  I have been driving on this f
  • I pinned this as I feel like it will help a lot of people see it.  As I said above Please print out the PDF or use another computer so you can follow the steps.     The process does work if
1 hour ago, Me78569 said:
Does the computer beep when you plug in the box?  sounds like either you have a charge only usb or the driver isnt installed.
Yes it does. I’ve flashed my box before with this same cord.
  • 8 months later...
not technically, but it is easier out of the truck for me personally.
Ok just tried, unsuccessfully, with the box still connected to truck and now have a cel.  Dash was going nuts during the process.
Edited by Mr. Bojangles
Added info
yep the quad is trying to enable the turbo timer using the power from the laptop usb.
It does work, but it doesn't always work the first or 5th time you try
Lol alright I’ll try again in the morning.  Looking forward to the smoothing of the ecm to Quad handoff.  The surge has been driving me nuts.
Thanks @Me78569for your How-To video.  I followed it and I was able to connect to my XZT+ and update the tunes without issue on my Windows 10 machine.
On 11/3/2016 at 5:03 PM, Me78569 said:
I am creating this thread to help people get The driver installed on Windows 10 if they have never done it.  I will not help outside of this thread so DO NOT PM me in regards to it.   If you are feeling like this helped you please shoot over a donation to the site.  It takes a ton of time and effort to keep something like this going.
The Quadzilla Flasher program requires NetFrameWork 3.5  Ensure you download that and install it if you don't have it already.
https://www.microsoft.com/en-us/download/details.aspx?id=21
*****For Windows 10 you must follow the Embedded PDF to a T.
******For Windows 8 the step 1 process will not work, you need to disable signed drivers manually.   Follow the webpage below and then run step 2 after you complete the below.
https://learn.sparkfun.com/tutorials/disabling-driver-signature-on-windows-8/disabling-signed-driver-enforcement-on-windows-8
****** For Windows 7 you don't need to run Step 1.  Windows 7 allows for unsigned drivers to be installed without alterations to the OS.  Only run Step 2.
Please print out the follow or use a second computer / Phone to keep this window up.  THIS WILL REQUIRE A REBOOT.
Once you have read and reread the directions you can download the flasher program.
Quadzilla Flasher Installer 32 Bit
Quadzilla Flasher Installer 64 bit
V2 Tuning will only work if you have the Iquad setup.  PV1 / PV2 and POD screens WILL NOT WORK
V2 Tuning Flash Files
The latest flash files are hosted here
https://mopar1973man.com/files/category/14-2nd-generation-24-valve-tunes/
Here is the APK for the New tune.  Quadzilla will update the play store to include it at some point You must enable installing apk's fomr unknown sources.
Andriod APK
Here is the API for IOS devices
IOS.api
Quadzillainstaller.pdf
I just want to say thank you. This was a long process for me to get this updated as I’m totally lost when it comes to using a computer but there has been a lot of time and effort into setting this up so that I could just click and download the stuff I needed and read the instructions. I just wanted to acknowledge that and say thank you so much for creating this it was a really big help!
Hopefully someone can help me out I'm stumped, windows 10 machine follow instructions but on step 2 where the black box and count down should happen I get nothing? computer recognizes there is a device as it connects and disconnects about every 3 seconds but that's it. Any ideas??
thats normal.  Try and flash the box.
I’m sorry Me but how or where do I find instructions to do that? I really appreciate the help man
please watch the youtube video in the first post.  It is a start to finish of the entire process.
10-4
When I did it I followed the PDF and it didn't work.  I then watched the video and did as he did in the video (there are some differences between the 2) and it worked.  I would suggest as Me instructed and watch the video and follow along with it.  I had the video play on my tablet while I did what he instructed on my PC.
Worked like a charm!
Thanks watched the video worked like a charm ?
Yep thanks man
