Turbo opinions
Hey guys,
So I'm finally getting close to ordering some DFI injectors! I spoke with Chris yesterday and after chatting about my truck and goals for a bit he recommended some of their 100hp .009 injectors. Now at the same time I'm also looking at rebuilding my hx35. I already have a rebuild kit from DAP, so I was planning to pick up a worn out stock turbo and rebuild it because I need a new compressor wheel as mines got a knick in one of the blades. Anyway, all this got me thinking that maybe there is a better option turbo wise. I have an edge comp right now and honestly, switching from the smarty had me disappointed with the lag. Smarty had zero lag, instant boost and I miss that. I'm looking to switch programmers again. Trying to get a quadzilla but may go back to smarty if I can't find a used quad. My biggest goals are instant boost, fuel mileage, and reliably towing up to 12k once in a while without having to worry about egts too much. All that said, what are you thoughts on turbos with 100hp injectors? What size and all that. Or should I just keep the stock one and rebuild it? Or a hybrid?
  • Replies 24
  • Views 6.6k
  • Meh not that hard to build it.  My code is posted so you just upload it to an arduino with a canbus sheild  plug some wires into place and call it good.       I should make a "lite" ver
  • leathermaneod
    leathermaneod
    Hmmm interesting. Do you have a source handy for a genuine wheel and silencer ring? And what about balancing if I put a different wheel on? That was another reason I had though of for buying another..
  • leathermaneod
    leathermaneod
    No I don't have a link. Just something I read somewhere recently. I'll try an see if I can find it again.  I just did a little digging on the subject and it seems I must have just read someone's
I think TFaoro and Nick are on point.
I like my 62 a lot, but i wish i had done a 451vge.
@leathermaneod I can tell you that 7x.010 SAC injectors and a stock HX-35 = High EGT's, Even with defueling the quad, it still wanted to peg the egt gauge, which led to my recent purchase of the Evil Fab 550HP Compound turbo kit S366/HX35. for 1500$ it took me 10 hours to install and the hardest part was disassembling and re clocking my stock turbo. Now my EGT's never climb above 1260* and I have boost any time I want it.
Thank you for the insight! I'll most likely be going with 7x .009 VCO's so hopefully that will be ok. I am still thinking/researching though so I do appreciate the input!
