2nd Gen Performance Woes
- Replies 49
- Views 9.1k
So I can help ya a little bit here. In my experience the 188/220 DOES make it a little harder to start during the winter. However, it should not make it as hard as it sounds right now. I don't ha
Do not get a 4k box. You will hate how it surges, be disappointed with the high rpm power, and streetability will suck. I have one. I ran it for a day and it's been on the shelf since.
Quad install should take you no more than an hour taking your time and routing wires properly! You've always got this site for help if you need it too. If you decide at some point you want to tr
Hey guys - I could use some help.
I've done a ton of mods to this truck and I have two issues - plus I suspect I should be getting a lot more performance.
1. Very difficult to start in cold weather. If I don't have the block heater plugged in I get a ton of white smoke and it's very hard to start until the temp reading hits about 50. This is with the Edge set on level zero. Once it hits a certain temperature boom! It's like a light switch and it runs great though it still smokes (whitish) while the extra fuel burns off. Floor pedal does nothing until it runs, Edge says APP is reporting correct positioning. I can hear the grid heater go 'clunk' when the key is turned on and I've checked the fuse. Fuel is good and I've even added anti-gel though it isn't near cold enough for that to matter.
2. Pulling a load, uphill, 4th in lockup I get a shudder at about 1,800 RPM through about 2,100 RPM. Does it worse under load though I can still feel it on a hill without a load. I have a trans lockup switch installed and If I force it into lockup it makes no difference. I can force it into third and force lockup and with the RPM boosted to about 2,200 the issue is very subtle to non-existent. I suspect compression stall. This seems to have started right after the Hamilton cam was added.
Other observations: Heavy black smoke when starting from a stop sign regardless of edge setting. MAP sensor is reporting pressure to the Edge (the edge is just an in-line insertion between the MAP and wiring harness) but if I disconnect the MAP completely it seems to make no difference to performance (I'm wondering if there's a break in the wiring harness and that's why it's over fueling). No check engine light when first disconnected though after fooling with it a half dozen times I now have a CEL that won't clear.
Help, guidance, wisdom and 401k contributions gladly accepted.
